More on Using the Nikon Lenses and GYHD100
The Jan issue of Digital Studios a Middle East Publication, has a write up on my use of the GYHD100 with Nikon lenses.
Below is the link. http://www.itp.net/business/features...gory=broadcast http://www.itp.com/magazines/current.php?magid=9 Yusuf |
Great article, Yusuf. Congratulations!
Great article! Very informative. I woudl like to get from you the information on two things: the contact person in Germany for the Nikon addapter, and information as to where I can rent/buy your documentary. I am very happy to hear such great information about the camera and how well is serving to the filmaking community. Thanks, Luis Otero |
Hi Yusuf,
Terrific read and I'm happy to hear about your success. |
More Info please...
Hi Yusuf - Great article... Have been thinking of buying the Nikon fit mount adapter from a company in the UK (les@lesbosher.co.uk) that has them in stock for £140.00 + vat - Can you tell me what benefits you have found by using the Nikon Lenses (we have a number of these 14mm - to 300mm) i.e - sharper? no CA? at what focal length do you begin to get better shallow DoF as compared to the stock JVC - when wanting to say soften the background when shooting a head & waist shot for example.
Many Thanks Stu... www.studioscotland.co.uk |
Nikon Mount
The mount is avilable from Zoerk at www.Zoerk.com, send him an email and he should be able to help, Andrew Young also bought one from Zoerk on my advise and is happy with it too. Both the adapters made by Zoerk and Les( I belive) are mchanical adapters, so should have similar results, though I have only used the one by Zoerk. The adapter does NOT give you the same results as you would get from a 35mm lens on a 35mm Camera, we have had a previous forum where this was disscussed in detail, below are the links.
http://www.dvinfo.net/conf/showthrea...ht=Nikon+Mount http://www.dvinfo.net/conf/showthrea...ht=Nikon+Mount http://www.dvinfo.net/conf/showthrea...ht=Nikon+Mount |
DOF/Nikon Lenses M2
We recently recived the M2 from redrock after 3 months, we are still testing it but thats the way to go if you want shallow depth of field and create a unique look. We are still testing and hopefully will post some results later.
On two Cameras
We have already tested it with DVX100 waiting for the shim kit which will ready today then we will test it on the HD100.
should give you a more compact system and a better image thatn the stock lens. |
Interesting
Will try this out.
Yusuf |
Go Yusuf! :-) |
Could you add more details about the difference between the use of the Zoerk adapter compared to the M2? I'm not familiar with these devices and I'd like to know what are you looking for with the M2 that you could not obtain otherwise (yes, I'm totally clueless :)) Thanks. -- Paolo |
Difference
The basic diff is with the nikon mount, the feel is still video the dof is not shallow enough to create the so called film look. But its great for mounting long lenses please read the above links for more info. On the other hand M2
does create that shallow dof using 35mm lenses, there has been a lot of discussion on wide angle lenses for the GYHD100, we did a test of mounting a 17mm nikon lense via the M2, its one the widest view I have ever seen through a Video Camera Viewfinder. Nikon Lens via the Zoerk mount, excellent for long lenses READ Wildlife/Sport Nikon Lens via the M2 creates a unique look, the closest you can get to a film look |
