HD100 and audio adjustments...
Does anyone adjust the audio settings to the xlr in puts on the HD100 when shooting?
as in using the "Wind Cut" option, or changing the db settings? :: efrain |
Hi Efrain,
The regular audio conventions apply. You have manual control over the audio circuits input as well as manual level control. You'll get incredible results with a high quality mic like a great studio mic (Rode NT1a or AKG) or shotgun mic (senn me66) or wireless lav mic setup (senn ew100 g2). The stock mic is Terrible (with a capitol T). On the stock mic you can not get really good sound because the noise in the mic itself does not allow you to bring the levels up and still maintain clarity and a decent noise floor. |
radical. cool. that's why i had asked in a previous thread about switching the stock mics for like ambient sound.
i own an AudioTechnica 835b shotgun mic, and we might use some lavs with the HD100, so i'm hoping it's cool. :: efrain |
I haven't had a chance to really test the audio inputs on the HD100 in the studio yet (meaning A/Bing direct inputs versus external mixer preamp), but it's not just the stock mic that's going to have noise. Self noise is inherent in any preamp and as a rule, camera companies don't go over board delivering the best pres...that's not their first concern.
Whenever possible, with most any camera setup, your best off going with a quality preamp like the Sound Devices Mix Pre (which is akin to the Shure two channel field mixer...perhaps a bit better). You use that as your input source and keep the camera inputs closed down to a minimum. As I said, I haven't tested the onboard preamps in the audio room through high end studio monitors, but I will soon. |
I measured -70db floor with 40' XLR attached to AKG Perception 200. I also had similar reading when I fed the camera from a Mackie CXF16mkII stage mixer. The preamps are great for a camera. |
That's what I've been interested in hearing. Obviously, for serious narrative work you're not going to record direct to the camera, but I like to have that option and it's nice to be able to do if you're dealing with mostly lock down situations. I'm glad JVC put in decent pres for that reason. I remember testing the XL2 against the Sound Devices in our room which is acoustically designed and treated and doing comparisons through our main console into the standard NS10s as well as big JBL studio monitors and the pres were so quiet and never needed to be pushed past the floor that we rarely bothered with a field pre. Again, I haven;t had any need to date to record audio onto the HD100 but just having it on to record background and visual commentary, it did seem to require more gain than I'm used to. Where have you found the average gain setting Stephen? |
Since no-one has really ever posted any audio from the camera with a studio mic plugged in I'll provide it to you Jim.
Click here for audio The camera's mic preamp 1 is connected to an AKG Perception 200 studio mic and the gain is set to 3 1/2. Hope you get something out of it. BTW: The Senn evolution wireless setup is excellent and the reciever mounts directly to the camera's shoe. |
Yeah...the specs look good. I'm in that place that I love so much, rewiring and installing new gear in the audio studio. It will all be done by tonight and then I'll get to do some listening with various mics and pres, but I'm hoping to use it straight for single mic use if it's that clean |
Sounds full and clean Stephen. It's funny how many people were/are skeptical about the HDV audio because of the compression issue. Granted, I'd like straight uncompressed for critical work, but I think most people would be surprised to learn how much broadcast audio is delivered to studios at 192 kbs MP3. I work with a few talent houses around the country and I still download my takes as aifs, but most of the independent talent send their work as MP3s. I like the Sennheiser gear and have that and AT wireless systems. I like the ME66 for run and gun situations but definitely prefer to use the Neumann and Schoeps for the critical stuff and any film work obviously. |
how to get uncompressed audio?
You may find that the onboard audio is acceptable for sources without a lot of dynamics and range. Push things to the limit by trying to record live rock music and I think you'll find quite a bit of unavoidable clipping of the audio signal.
PCM audio definitely important to have available
I'm still in my first days with the camera, and I haven't got to investigating the post-production workflow yet, but I certainly hope to test this pronto. |
