FAQ it
Any good HD100 FAQs?
This place could sure use one for questions like which tape do I use? is SSE fixed? does HDV suck? etc etc. |
1) You can use any DV tape. The data stream is actually smaller in HDV mode than SD. You don't need special tape unless you really feel you need it.
2) All HD-100's produce SSE under extreme conditions (i.e. 18db gain in low light). It is a design drawback used to make the camera energy effecient and cost effective. 3) HDV doesn't suck. It does however allow for High Definition recording on standard DV tapes with cameras that cost less than 10K. |
great suggestion bruce - as a new owner, I'd love to have a user generated practical FAQ... to address issues, suggest accessories, suggest cheaper alternatives... 1) Cheap additional battery 2) What to check for when the camera arrives (check for "A" nameplate...etc) 3) Best post production workflow - If you use Vegas - do this - If you use Premier Do this... maybe some sort of wiki.... (idea bulb) maybe I'll install wiki in my server... |
This place is what you guys make it. If you want a FAQ here, just start one here. I'm sure Tim and Nate (our forum moderators) will be all over that idea.
Ok Here is it - its up an running
http://snipurl.com/HDcamWiki I have updated it with the following questions:
1) What is SSE? 2) Can it be fixed? 3) Which type/brand of mini dv tape is best suited for the camera? 4) Is Jvc's brand of HDV unique? 5) What's the difference between the 100 and 100"A"? 6) What are some of the battery options? 7) What is Chromatic Abberation? 8) What are the best editing solutions? 9) What are the analog "outs" for? 10) What is a good camera bag for the camera? There's ten, maybe they're not the greatest questions, but it's an official start... |
http://www.dvinfo.net/conf/showthread.php?t=57175 My biggest problem is that my completely nutty schedule (combined with my type A personality,) has prevented me from posting an incomplete FAQ. I'd prefer to post a FAQ that is complete, accurate, and objective with all the goodies the "official" documents don't talk about. JVC has a couple FAQs for the HD100, but keep in mind most were written by marketing. http://www.jvc-victor.co.jp/english/...faq/index.html http://pro.jvc.com/prof/attributes/f...&feature_id=13 |
Tim's nutty schedule gives me a little time to implement our CMS / wiki component!
It's coming; it's just late, like everything else. |
Thanks Ram!
Great job putting that Wiki page together, I'm sure it will serve the community well. Kudos!
-sam |
Better to hold off on the kudos until it's actually delivered! Heh.
Here's a wiki that's been up for a while too: http://showiki.com/wiki/Equipment_InfoBase
should we try and consolodate these various faqs?
suggestions? |
I think you should. I just looked at two. Sure I can add information but how many came one person do. Can't find them all.
It is easier if there were here. Just my opinion. And the idea of the wiki is that the information can be edited/altered. But by whom and is it correct. Here there is a moderator. |
