Jonathan Ames |
June 7th, 2006 08:44 AM |
For months, I've heard more bad things than good about the 100hd's ability relative to producing footage that will stand up to chromakey and wanted to finally make comment. I hope you all have good results because when we started 2nd Unit that debuted at NAB,(before we tore it apart to incorporate the live webcast properties everyone wanted), people were amazed with the results we achieved with even the 4:2:0 footage much less than 4:2:2 in chroma. We've shot 3 of 4 2006 series shows for OLN keying the color commentary booth (because of site/set limitations) which was shot after the competition and then cut it in for the final show. Mike Pellagatti set the lighting for the chroma which was bright and failrley even but not overly so because we were using Serious Magic which is a great and forgiving program if used correctly. Anyway, the only problem we experienced was having to move the final output from a dark moving backgroune to a static light colored set to accommodate the 4:2:0 tape. The 4:2:0 footage simply fails to be able to carry the edge well enough when contrasts are big but at component out via 10A to disk with 4:2:2 the problems are, of course, mitigated and any background can be used. But that does not mean that tape from the 100HD is unusable. Simply reduce through forward planning the contrast ratio betwen the talent and the background when you're keying from tape source will be fine. The combination of Serious Magic and the 100HD is a good one for broadcast and a great one for independent contrary to what many people say and yes that's in SD and HD. Subject wardrobe and background in HD is just alot more critical. The trick is in knowing the limitations and working with them. Paolo's podcasts and standard content on his cruiser site is an excellent example of what can be done with Serious Magic. If I'm not mistaken, he used one of Serious Magic's motion sets and it looked fantastic.
