Short film shot using mini35 + Zeiss Superspeeds
Hi Guys,
I just came off a short film I shot with the HD100(A) with a mini35 rig, using Zeiss Superspeeds (18,25,35,50,85) We also had a Canon 300mm lens which was amazing. See pix of the rig below. It was a very nice rig indeed and very impressive on the set. The footage turned out quite amazing. The producer and director are very happy. In fact, in their words, the footage looks "phenomenal." Here I will share my experience with this rig and the resulting footage. We shot for 5 days straight in San Francisco and had a 3 ton grip/ lighting truck. I used Paolo Ciccone's Tru color v3. with a slight difference, however, I still like shooting with Black Stretch 2 for latitude later in post - so that's the only diff. Some quick grabs from the footage. The film is a 15 min Wacky Comedy called "The Wondrous Woman" (these have been saved as JPEGs and most color corrected) See if you can make up the story from these images: http://www.pointzeropictures.com/video/WW-in-Park.jpg http://www.pointzeropictures.com/vid...Restaurant.jpg http://www.pointzeropictures.com/video/Cops-and-WW.jpg http://www.pointzeropictures.com/vid...igure-Play.jpg http://www.pointzeropictures.com/video/Park-Sean-CU.jpg http://www.pointzeropictures.com/video/Meeting-MM.jpg http://www.pointzeropictures.com/video/WW-Dance.jpg http://www.pointzeropictures.com/vid...The-Horror.jpg Two major things that I notice that are due to the JVC's shortcomings are a pruple to green gradation from top to bottom: http://www.pointzeropictures.com/vid...oom-before.jpg ...but it can be fixed painstakingly by removing the purple -green color cast later in post: http://www.pointzeropictures.com/vid...room-after.jpg and the other one: Serious Color Fringing example on highlights: http://www.pointzeropictures.com/video/WW-waking.jpg ...but nothing that can't be color corrected by secondary color correction: http://www.pointzeropictures.com/video/WW-waking-2.jpg images of the actual rig : http://www.pointzeropictures.com/vid...ni35-rig-1.jpg http://www.pointzeropictures.com/vid...ni35-rig-2.jpg http://www.pointzeropictures.com/vid...ni35-rig-3.jpg http://www.pointzeropictures.com/vid...ni35-rig-4.jpg .. and last but not least - yours truly (this is NOT how I go on the set - I'm home, OK? so give me a break!): http://www.pointzeropictures.com/vid...35-rig-me2.jpg ........................... Miklos Philips DP Point Zero Pictures http://www.pointzeropictures.com http://www.imdb.com/name/nm0680106 |
Thank you, Miklos.
Looking great ! Can I ask you if you were rolling tape in the cam or was this an analogue capture to a deck/other codec ? tia, Rob |
Capture
Recording to good 'ol tape only. It was clean - no drops, using the Panasonic AY-DVM63MQ.
We used a bunch of IDX bricks for power with a D-tap that powered the HD LCD Matshall 7" on board monitor as well as the camera. The camera was running pretty much all the time for our 10-11 hr days. We usually went through 2 "double-bricks" the E-10s Endura batteries, and one E-7S "singe-brick." The mini35 was powered by a JVC battery mount in the back. We only used about 2 /day (BN-V428U). Much to my dismay I discovered 4 shots out of 5 hours of footage that were shot with the mini35 OFF. This was usually accidental - as much as we constantly checked to make sure the mini35 was running it somehow happened anyway in the madness of shooting. The design is pretty stupid and the battery contacts are atrocious the way it's mounted on the back of the mini35 rig. We even gaffer-taped it to secure it better, but when one moves the camera it can be bumped easily and the mini35 will go OFF. Always ALWAYS check and check again the mini35 is ON before you roll tape! |
Thank you !
You sure the color fringing is the JVC's fault? You're not going through any of the stock glass with the mini35, maybe it's just the lenses you're using.
I believe that the color fringing may be due to the cinegamma on the JVC. Many posts were made regarding this when the DVX was released some time ago as it suffers the same problem--as do most video cameras--as they don't do well with blown-out highlights.
Is ths something that you can verify Miklos? What gamma were you using? |
Mikos:
Next time with the Mini on an important project, you should consider using the Anton Bauer mod for the Mini35--will power both rig and camera for many hours, much more dependable than the camcorder batteries and you can leave the "ozzie" on all day which helps prevent shooting with it off. I have a custom one that I rent out if interested. |
Sounds good
The fringing problem showed up with different lenses. Since these are super fine glasses, Zeiss Superspeed primes, I don't think we're talking about the same sort of issue as you get (CA) with the cheap miserable stock lens. Using different focal length primes this fringing showed up around contrasty highlights or even just plain contrasty sharp lines as purple or green fringing. I do believe this is the CCDs in the camera and not the lenses. I haven't tested it this time, but I can bet you anything if you did some tests with contrasty subjects/ lines you'd get the fringing or simply pointed the camera at a flat white wall you'll see purple-green color gradation. This seems to be a JVC "feature" (thanks very much) and has to be dealt with later in post. I shot other films with the SD SDX900 with the pro35 adapter and nothing like this showed up. That's where we're talking about a $30 G camera vs. a $5 G camera. |
The fringing reminds me of the effect you used to get with out of registration tube cameras. Of course you could sort this by lining up the camera using a registration chart and adjusting the settings on the other tubes to match the green tube.
The alignment could be a bigger problem on the large production runs that you'd get on the 1/3" cameras compared to the more expensive 2/3" cameras. HD will be pushing the tolerances compared to SD. It would be interesting to test the same optics on different cameras to see if there are variations in the fringing. |
The images looked great, BTW. Nice look. When do we get a chance of seing the movie, looks hilarious! |
things I learned using this rig
Here's a list of things I learned using this rig (as I think of them):
-- Need a lot of light to give yourself room to play with the F-stops and DOF (otherwise your Focus Puller/ AC will kill you) here I mean do not work at wide open. I usually hovered between 4 and 5.6 and we had a ton of lights. I usually set the desired F-stop for my desired DOF depending on the lens and then used the relay F-stop (behind the mini35 - this doesn't affect the DOF) to stop down if I needed to. Even on the relay I avoided shooting at wide-open as I noticed a slight softness when at wide open. (I read somewhere else NOT to use the relay at wide open as well) -- Definitely have a good focus-puller/ AC -- Definitely have an HD monitor on set -- Remind your AC to handle the lenses very carefully when swapping. The rear element (glass) sticks out (on the Zeiss Sueprspeeds at least) and can be easily scratched on the mini35 mount - that's abut $3 Gs. -- Forget handheld shots unless you're Hulk Hogan and have a "steady-stick" or something -- Watch the battery that powers the mini35 on this rig, the design is awful and the contacts are flimsy (we had 4 shots where the mini35 was OFF out of 5 hrs of footage) EVEN THOUGH we constantly checked, not a bad ratio but you don't want it to happen on the best take the director wants to use more to come... |
That's nothing to sneeze at. |
Ouch!! I was always under the impression that the color fringing was due to the cheaper factory 16x lens, not the CCD. You are hurting my reality. ;)
Regardless, thanks for sharing! |
I still think it's a possibility that since this was a film lens, the color fringing we're seeing is in a wavelength that film is not as sensitive to as a CCD, so the manufacturers of the lens didn't get rid of the CA at that wavelength.
It's either a problem within the optics of the the Mini 35 (assuming you're not using the stock JVC lens, but the Mini 35 with it's own lens for the JVC), the lens on the JVC (if you are using the stock lens) or the optical block/CCDs of the JVC camera. |
The post is out of my hands, but they tell me they will crank on it and have the film cut in a month or so. Then it's on to festivals - the usual. It's unfortunate that the public doesn't get to see some of these shorts, unless a small percentage of them goes to festivals (and the film gets in). |
I would rate it at more like 120-160 ASA. |
BTW: I know these may have been posted here elsewhere, but here are two very good articles/ info on Chromatic Aberration for those inclined to learn more about it : http://en.wikipedia.org/wiki/Chromatic_aberration Wiki http://www.vanwalree.com/optics/chromatic.html - a great piece by Paul van Walree |
And an article from Canon: http://www.usa.canon.com/industrial_...WhitePaper.pdf
Noise/Compression
Milkos: I've read reports from other Mini35 users (such as Nate Weaver) that the HD100-Mini35 Combo produces a lot of noise/grain to the point where it no longer looks good in HD. Also Barry Green noted that the preproduction model they tested had MPEG compression echoes when using the Mini35. Did you notice either of these problems? The frame grabs look very nice and every bit as clean as shooting with just the stock lens.
Here's a full rez (720) screengrab from the shot (density corrected to pull it up for computer displays, but no other correction - and was saved as a PNG, not a JPEG so no more noise is introduced) - it may take a while to load, so patience is reuqired (1.23 MB): http://www.pointzeropictures.com/video/Chase.png I kind of like the grain, as it's more "film-like". |
