Focus Assist
Ok, well if those whose been reading my posts, knows I'm a newbie....sort of.
How does this focus assist do anything? How does it work -- or how do I focus with it? Next question is what's the RGB settings, is there a purpose for each one? |
I'mnew to this cam too, so don't feel like the Lone Ranger dude.
The focus assist is supposed to form a tight blue line around the edges in your viewfinder when you are focused. With me, it's like looking at a 3D movie without the glasses. But, not only am I new to this cam, I'm also old. It's getting harder to trust my eyes. Most other folks feed the image out to a HD monitor, to make sure the focus is right. I don't have those nice toys yet, so I have to go with what I see in the VF. Something that does help me, is the Peaking knob, up on the handle. Crank it all the way up, and it rings the focused subject in white. |
You can also set the focus assist color to green or red. I find green to be the best, especially in low light. I use peaking more often because it amps the details up so much that it makes it pretty easy to tell what is in focus even when there is not enough highlights. |
Focus Assist draws colored pixels wherever it detects a sharp edge. When you achieve focus the edge should appear to jump out at you.
Ok....well i'll keep trying, as far as I know, going from 1ft to infinity doesnt change much. For instance their will be things in the bg colored as well as the foreground, so hard to tell which is in focus, only way I can tell is by guestimating the distance. Another thing I noticed is the focus ring actually moves the lens into the image slightly, do you get this?
--open the lens all the way (use the neutral density filters and/or the shutter speed if necessary to get an approximately correct exposure--this is not for shooting, just to observe the focus assist function) --zoom in on something across the room or across the yard that is isolated from other objects by distance--that is all objects in front and bac and to the sides are at least several feet away. Now turn on the focus assist and adjust the focus. The edges of the object will show the color when in focus. The lens wide open and the zoom in will limit the depth of field to maximize the effect of the focus assist when the isolated object is in focus. |
I believe the focus ring question is related to the heavy breathing of the stock fuji lens. It sure does breath! I hate those 800 dollar lenses! ;) |
haha. Well guess that answers the movement. Anyways what I meant was, yes I am shooting wide angle, I hate zoom lenses period, so I try to stay mostly wide as I can and go from there. I guess focus assist really doesn't help much in wide.
If part of the picture is key, zoom in and focus on this, then zoom back to ensure the key element is in precise focus. However, be sure the back focus is setup correctly so focus will be the same on both ends of the zoom. |
Oh boy. I really am an idiot today. I totally forgot with zoom lenses. Zoom onto the subject, focus it, then zoom back out. Sorry guys ( :
Any news on what the new adapter that JVC is coming out with will cost? And when? |
