-   JVC GY-HD Series Camera Systems (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/)
-   -   Best cinegamma setting for hd100 (https://www.dvinfo.net/forum/jvc-gy-hd-series-camera-systems/75218-best-cinegamma-setting-hd100.html)
Amos Kim September 10th, 2006 06:57 PM
What setting for cinegamma do you guys think yields the most filmic image? What do you guys use?
Tim Dashwood September 10th, 2006 08:22 PM
It depends what you consider to be "filmic." It is very subjective and hence hard to answer.
If you are looking for film-like gamma response, then use the cine gamma curve. If you are looking for as much dynamic range as possible, lower the knee and stretch the blacks.
Colour-wise, experiment with the scene files available, and don't be afraid to play with the settings. Many people have achieved a pretty close "Kodak" look with my "WARM" scene file. You may want to try that as well.
Amos Kim September 10th, 2006 09:34 PM
what number setting would you set the cinema gamma at?
Tim Dashwood September 10th, 2006 10:35 PM
I set it to -3 for most of the last film I shot. That doesn't necessarily mean you should. Testing is the best bet.
I've done alot of testing under different conditions and for the most part I was using completely controlled lighting, and I carefully controlled my ratios.
