Wide angle
Hi,
I can't afford the full replacement wide angle lens, so I'm looking for suggestions as to what is the best/cheapest way to get a wider angle on the JVC? Are we talking some kind of cheap mini 35 adaptor and 35mm stills lens, or is there any decent wide angle adaptors for the stock lens? (the JVC adaptor does not seem very wide in my opinion), Thanks Paul J |
I've not seen a wide angle adaptor that makes any sense in terms of performance/quality. I think it would be great if one of the rental outfits in the UK started to supply the 13x lens. I spoke to a couple a while ago and they said they just didn't think there was a market out there for it. Does anyone in the UK know if there is actually someone offering the lens for hire now?
Hi Paul
As a cheap alternative check out: http://www.b-hague.co.uk/Wide_Angle_Lens.htm I believe JVC does a wide screw on adapter too. Cheers Gareth |
I have the JVC .82 WA screw on adapter and it's saved a number of shots for me allready where it simply wouldn't have worked without.
You can get the wider stuff as well, but as it's not zoom thru I had to rule them out. Especially with how touchy this camera is for focusing. If I couldn't zoom in and get a good focus (even with the focus assist) i'd be in trouble for sure. it's definately not as wide as I'd like it to be, but it's sure better than stock! |
whats non-zoom thru?
If the idea is to get a wideshot, why zoom? that narrows the field of view..right? |
This can become quite an inconvenience in documentary work, and therefore a zoom-thru adapter is much more desirable. |
While the JVC adapter isn't really wide, it's pretty wide, all thing$ considered, I'm glad I got it, I use it quite a bit.
lens vs. adapter
I have the screw on adapter and it comes in handy on more occassions than I thought it would. If I'm doing some run & gun shooting I leave it on for the whole day. My mattebox even fits over it. However I have a shot coming up that I don't think the wide angle adapter can handle. Now I'm in search of the 13X lens for rental. Any suggestions? I'm in the US.... North Carolina. I don't mind getting it shipped in, I do it all the time. None of my sources have the 13X lens for JVC HD-100 though.
Are you sure of that? I was under the impression that you would be able to use the lens at any zoom setting, but that it would change the focus point so any moves of zoom would require a refocus. I could be completely off on that tho.
I just did a job with 2 HD100's. One with and one without the Wide angle lens.
It turned out during shooting that the wide angle lens could not be used to zoom all the way. It was not possible to get it sharp fully zoomed in. I checked the back focus, which wasn't the problem. |
That's not the same lens - it's probably a 2/3". The 13x in question is a 3.5, not a 4.5. I have rented it from them and paid a lot less (unfortunately I don't remember what). |
