Low light esp. 480p60 mode
As a long time user of the HD10, I was always glad to have the 480p60 mode as it gave me a full stop of sensitivity or more for those times when it was just to dark for HD. And of course gorgeous 60fps that upscales nicely to 720p.
Now I was considering the HVX200(briefly), mostly for multiple frame rates, and P2 (I do short film and it would work well for that) and SD modes that I assumed would have excellent low light ability much like the SD DVX100. But when I asked on the HVX200 forum I was told that the SD modes offer no low light advantage over the HD modes. I don't understand why this is so, but it is. Now my question for HD100/200 series cams is, does the 480p60 mode give you a big jump in sensitivity like the older HD10 does? |
The HVX200 doesn't get that much of a boost because the sensors are pretty close to standard def in the first place, it uses pixel shifting and upconversion to get 720p.
So why do I get a full stop or more when going from 720p30 1/30th to 480p60 1/60th(even more if I go 1/30th) on the HD10? Doubling the frame rate and double the shutter and I still get a big jump. Sensor resolution is close to the HD100's. So what give's.
Secondly I would have to ask, has this been tried or is it just educated guessing? Does the HD100/200 really do nothing when you switch from 720p to 480p? |
***BUMP****
Can someone please help me out with this. It would only take a minute. A simple shot out the window would do. Lock the shutter and exposure. Take 10 seconds of footage. Switch to 480p keep the same lacked shutter and exposure. Take 10 seconds of footage. Play back. Thanks in advance. |
Ken,
I tried what you suggested with my HD100 and can tell no difference in light between 720p/30 and 480p/60. Shutter was 1/60 and iris was locked at 5.6 in all modes. I verified this in Vegas by comparing the waveform monitor between the sequences. |
Steve Oakley |
The fact wether or not you'll improve in low light capability is a question on how the DSP in-camera works. This can be either way: the signal (photon-count) of several small HD pixels (within the spot of 1 'SD-pixel') might be added to each other to result in a new (and brighter) 'SD-pixel' and thus improved low light capability. Also, the camera's DSP can process the image in HD and then transfer it to SD to put it to tape. What happens then (effectively) is that an average is taken of the signal of all HD-pixels that constitute 1 SD-pixel. Low light capability doesn't improve this way, but overall image quality is somewhat better because the image processing (DSP has been done before the down-rezzing...
None of the explanations seem to cut it for me. Especially the its a one chip, argument. I am shocked that there is no sensitivity increase for the HD100/200 series. It was something I could always count on when using the HD10.
The sensors in the camera are more sensitive in SD mode as you'd expect from your HD10 experience but not quite as sensitive. We used to pull the old 30 shutter speed trick in order to get more light to the CCD's in order to keep from gaining up. In the case of the ProHD camera's you can bypass those tricks by using your gamma setting as well as black stretch and black compress in the menu. take care, S.Noe |
Just read this thread....
in my experience with DV and now with the HD110, it's pretty clear to me that the HD110 has about 1-2 stops more latitude than my XL2. Improved latitude is quite different from low light sensitivity. I 've had the occasion to shoot several venues in very dim incandescent light. I was surprised at the quality of the recorded video, even at 9dB gain. |
