Hd100's sweet spot?
A lot of people say video cams often work best at 5.6. What are findings with the hd100?
f4 - at least with the stock lens.
Brian, great question. That was what I wanted to find out today. As we all know, wide angle with the stock lens just plain sucks in resolution compared to say an XLH1. So I wanted to find the sweet spot of the fuji 16x for myself. In short, I get the sharpest images @ f5.6 and the focus barrel @ 15 feet. At the longer end, the HD100's stock lens just shines (f2.8 to f8.0) except at full telephoto. This is all from my unscientific tests.
Eric's answer may be a lot more accurate than mine.
Eric, you live in Savannah? That's my 2nd favorite city (1st is Charleston). I used to live in S. Carolina!!! Now I'm stuck in the ice box capital of the west. But at least Sundance is here. |
2.8-4
at 5.6 there is generally too much DoF unless you want deep DoP once you go past 8, you start running into pinhole effects from the smaller apeture. I often flip the ND filter on, even when shooting inside to get back to 2.8 1/2 Steve Oakley |
Outdoors in the sun I add an ND .6 on top of the ND 2 of the camera to reach the f4.
It's all a bit dependant on taste, I suppose, but FWIW never OPEN (abberation limitations of the lens) and never over f8 (diffraction effects will take the 'wow'-factor out of the HD)
even f/8 is a bit soft. for me f/4-f/5.6
All the way open creates "white shading" where the upper 1/3 of the screen has a magenta cast. I wish they would fix that in the firmware. |
Is this not so? Anyone with a wide angle lens out there having this happen? john evilgeniusentertainment.com |
cameraman
I read in one of Mr. Carl Hick' posts (JVC rep) that the white shading has been fixed in the 200 series. I was on the verge of buying the HD 110, and this has put me off it as I was starting a new film which features much long lens shots of the outdoors. Now skys are generally blue, but not all and not always purple!
Can JVC fix this with a firmwear upgrade which i'm sure owners would pay for? |
no, it happens when the iris is full open. seems silly that it would do this. Full open should be possible with no excuses. They should correct it. |
I've never seen the problem with the stock lens mounted, but I have had it with my canon 50mm 1.8 direct mount. I think its more about reflections between the CCD block, the back of the lens, and maybe something shiny in the lens mount area somewhere.
Steve Oakley |
I only have the stock lens.
I see it everytime I open up all the way. |
Me too. With the stock lens and the 17x as well. Have to close to at least f2.8, better at f4. Sure wish I knew what was causing this.
Gary |
