Image Inversion Software?
I'm want to capture some 720 24p footage from my HD110 / Redrock M2 into FCP Studio. We are using a PowerBook. Is there a good 3rd party software that can re-invert the image upon capture without resolution loss? Thanks.
re-invert?
There is a plugin for inverting an image in fcp, that would be converting a scan of negative film into a positive image. thats inverting something. is that what you mean? |
I know Cineform Connect HD ($200) on the PC side has a check box for M2 image filip that they developed with Red Rock Micro. On the MAC side I'm not sure if the new public beta version of the Cineform Codec has the capture option or not. www.cineform.com The HDLink capture tool in Connect HD can capture in m2t or Cineform. So if you want to edit native m2t, you can.
Try to make sure that you convert to the least lossy codec, and try not to recompress until your final deliverable. |
If you are using a intermediate codec and converting m2t files, then MpegStreamclip v1.8 does have the inversion option in he Quicktime export pane. |
Why can't you just apply the effect in FCP? Double click the video, open the Motion tab, and change rotation to 180. Copy the clip. Then for every other clip you put in the timeline, use the Paste Attributes and check mark the rotation option. Then all your video will be flipped right side up.
You might even be able to apply it to one clip in a sequence, copy that clip, then paste attributes for basic motion to clips in the source bin. THey should then be able to play in real-time (if you have enough processing power.) |
Yeah, 180º as long as the Redrock only makes the image upside down and not actually backwards. In that case you would have to change the corner pin in the Distort section of the Motion tab.
As far as loss is concerned, if that is a major concern in a particular edit, in Premiere you can capture your entire file, flip it in once in the sequence, then chop it up on the time line using razor cuts, and the flip is already applied on both sides of the cut. Edit, render to final. That actually one unintended benefit in not having scene detection available for HDV in Premeire. Vegas will work the same way. |
Maybe you're concerned with added compression. The usual rules for any rendering will apply, regardless of NLE. |
wait so you mean that there is an issue just trying to flip the image once your ready to edit?
