Actual Resolution
Just a quick question. What is the actual resolution of the files those of you using FCP are getting with the 100? All my file are coming in at 1248 x 702.
I'm wondering if this is normal or if I'm not getting the res I should be? |
Quicktime player is reporting the size wrong. They can be nothing but 1280x720.
It's a bug, I've seen it as well. |
Thanks Nate.
It was quicktime I was looking at, but a computer monitor with component in that I just returned also claimed a lower res of 1220 something by 696. I assumed it was the monitor until I noticed that some of my quicktime were saying the similar low res numbers. This morning I noticed that my kona captured dvcprohd clips report the same actual res of 1248x702 as my firewire hdv clips. So this is a flaw with how quicktime reads its files, good to know. |
Bryan & Nate-
How are your clips coming out regarding digitizing HDV as DVC Pro HD? Do you notice things going a bit soft? Or maybe you can't see a difference? Thanks. BTW- I haven't decided on Kona LH or Decklink HD studio yet. Waiting to see what happens at NAB. |
Justin, Most of the stuff I've captured with the kona looks quite good. There is a bit of softness compared to the hdv but so far I'm pleased with the card and it's results. I really like that I can digitize realtime without brakes in the long shots I do. The footage is also a lot easier to work with in FCP.
