For example, while making TrueColor for the Canon A1 I found that the WFM squares were a little too "fuzzy". I could not detect the cause by naked eye, even when looking through a decent size monitor. It turned out to be the detail circuit to be the cause of the noise. Apparently the edge enhancement would "wiggle" continuosly and create a lot of un-necessary noise. You cannot see that when checking the scene via the display or the viewfinder but it will be visible later on on a bigger display. The WFM and histogram display are you objectve friends :) that help you check the image quality. |
Thanks I will check it out
Hi All,
Thanks for the feedback. I will do more tests to see where I'm messing up my lighting. I'm sure it's just lack of knowledge. But you have to start some where. I will continue to use my totas with some accessories as most of my close up shots look really nice. I was trying to shoot 4 people in a bigger room. I didn't have a generator and the building had an old fuse system, as apposed to breakers. I shot with 800w total, plus the room had a lot of smaller lights. It was a rush job so I had very little time to test different setups. So in the end, probably have enough lights, just need to learn how to use them better. Thanks again, Jon |
That could be the problem Jon, 800w for four people in a dark environment. With this camera you need about 800 watts for one persons! With four you'd need to run over 2K in a dark room to make the camera happy (won't make the people happy under all those lights). This camera creates a great image, but at the cost of sucking up light like there's no tomorrow. Keep working with your lights and be ready to direct a lot of light at the subject to bring the camera into it's sweet spot.
Ben |
Just as an update I did bump the luma up to +1 and that eased the light consumption noticably with any noticable degridation of the picture. So now if it's dark the luma gets bumped a little to save a stop or two.
