More Questions about Nikon Lenses on JVC
I work on a nature show (with plants and animals) and we recently started using the HD250. Sometimes I need more zoom than the stock lens has, so I'm thinking about getting the adapter and a Nikon 80-200mm f/2.8D ED AF Zoom-Nikkor Lens. For those of you that have used Nikon lenses on the JVC cameras (especially those doing nature/wildlife):
Sound like a good lens choice? How well does the zoom and focus work when using a Nikon lens with adapter? How is the back focus adjusted? Is this a setup where any kind of quick adjustments are out of the question? Also, do you really need one of the rod lens support system for a 300mm zoom nikon? People have mentioned needing a heavy tripod when using nikon zooms. I have a Cartoni Focus head on Cartoni Composite 2-stage legs. Weighs like 11 pounds. Heavy enough? Or do I need a really heavy one? We have a pretty heavy O'Connor tripod but would rather not bring it. Part of shooting wildlife in the field is carrying the equipment, and I don't want to bring anything heavier than necessary. Oh, and how well do Nikon macro prime lenses work for flower closeups? Anyone doing that? |
Along similar lines ...
I can't answer the above, but I'm also interested in finding out where I can get a lens adapter for the JVC body to attach Leica or Canon FD lenses?
Bear with me, as I'm still trying to figure this stuff out.
As far as I know, there are three places for basic Nikon lens adapters. These add around a 7X magnification factor to your lens. MTF in London at http://www.mtfservices.com/ <---this company also claims to make one for the Canon FD lenses Zoerk in Germany at http://www.zoerk.com/ Les Bosher at http://lesbosher.co.uk/ Then there are 3 that make ones that change your depth of field. These aren't just adapters, they are much more active components for making your video look like film. I think they have little to no zoom factor. Letus 35 at http://www.letus35.com/ RedrockM2 at http://www.redrockmicro.com/micro35.html Brevis at http://www.cinevate.com/ Then there's a P&S Mini35 at http://www.pstechnik.de/en/ . I'm still learning about this stuff, and am not sure where this one fits in. Oh and looks like another at: http://www.sgpro.co.uk/ As I am in a position to NEED the added 7x magnification for wildlife video, I am interested in the first three. Are there any other adapters that should be added to this list? Are any made in the U.S.? |
Why does everything look so magnified? I just added a 55mm nikon lens usinf an MTF adapter I just bought. WHOA! everything is so...so close.
55 mm on a 1/3 chip camera is the equivalent of about a 400 mm lens. Wide angle for 1/3 chip camera is about 4.5mm.
so what good are these adapters? Wild Life? Is there a chart that compares the mm lens equivalent? |
Scott, I've used the mini-35 both with Hasselblad (wow !!!) and with Nikon primes.
Two things: 1) reduced DOF requires very exact focussing work - camera assistant with tape measure required, or VERY good field monitor 2) mini 35 with rods and battery and all adds substantial weight. I cas still be used handheld but it's a big weight and not very handy for wildlife docu I would think unless you are filming for the 16/35mm type market. Maybe Canon or Fujinon have a more powerful zoom lens for the 250 ? Be sure to test it before buying. |
Nikon lenses
I use the Redrock Micro adapter on my JVC 200 cam. I use 3 Nikon lenses (28mm, 50mm, 85mm)
Once these lenses are attached properly (which takes some setup time) there is no zoom to them. When properly setup, the results are spectacular, however I would not recommend this setup for "running and gunning" or shooting anything that you don't have total control of focal length and a great monitor to judge your focus. Focus is so critical with this setup. Hope this helps steer you in the right direction. Would you be offended if I said "Go Gamecocks!" :) |
