Mixing SDHC Cards in HM700 ? at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old May 29th, 2009, 10:28 AM   #1
Can anyone confirm it's ok to:
1.) mix two different brands of cards in the cam at the same time?
2.) mix 8 GB and 16 GB cards in the cam at the same time?
Thanks in Advance!
Ron
Ron Edwards is offline   Reply With Quote
Old May 29th, 2009, 05:02 PM   #2
I don't know, but I will confirm that both are okay.
Before you discount my answer, ask yourself how times you have asked for directions, the person said, "I'm not sure," and then they gave you directions and you continued to listen.
Old May 29th, 2009, 09:18 PM   #3
How could I "discount" such a response .... it (the answer) would first have to have value in order to eligible for any discount.
RonE
Old May 29th, 2009, 10:33 PM   #4
I have seen nothing to even suggest that the cards in the slots must match.
On the contrary, all you need is one card in either slot. While one card is recording you can change the card in the other slot. This strongly suggests the slots are independent of one another -- except when one switches to the other -- and the size of the card in the slot is unimportant. The brand of the card would also make no difference.
Old May 30th, 2009, 01:12 AM   #5
The SDHC-Class must be 6x (it allows a writespeed from min. 6 MB/s.), the brand or the size don`t make a problem.
Eric Deyerler is offline   Reply With Quote
Old May 30th, 2009, 06:56 AM   #6
OK..thanks!
Ron
Old May 30th, 2009, 09:02 AM   #7
I can confirm that the camera moves seamlessly from a 16gb Delkin to a 32gb Transcend card without dropping a frame. Never had a doubt before trying either!
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply With Quote
Old May 31st, 2009, 11:15 AM   #8
I confirm too as long as you use class 6 cards. Also.. I am using cards not listed among the "officially supported" ones in the manual with no problems at all. Still I have on doubt. The camera is supposed to be 35 Mbits but the cards are said to be 20... how can it work ?!?!?
Marcello Mazzilli is offline   Reply With Quote
Old May 31st, 2009, 11:29 AM   #9
That is the difference between Megabits and Megabytes. 35 Megabits per second is 4.375 Megabytes per second. So class 6 is guaranteed 6 Megabytes per second so you have a safe 1.625 Megabytes per second overhead.
Elvis Ripley is offline   Reply With Quote
Old May 31st, 2009, 11:31 AM   #10
A Class 6 card transfers a minimum of 6 MB/s -- which is Megabytes per second.
The video is written at 35 Mb/s -- which is 35 Megabits per second.
There are 8 bits to one byte. Consequently a minimum of 6 MB/s transfer rate is the same as 48 Mb/s transfer rate.
Note: Class 6 equates to a 40x card. Many Class 6 cards are actually much higher: 66x up to 300x. Obviously with video that has a fixed maximum write rate, the faster cards are not necessary, and a slower Class 6 card -- which would be cheaper than a faster Class 6 card -- would be fine if it is of dependable quality.
These two Wikipedia pages give details:
Secure Digital card - Wikipedia, the free encyclopedia
Data rate units - Wikipedia, the free encyclopedia
Old June 5th, 2009, 05:18 AM   #11
I know the megabytes / megabits issue... is just that on the box of teh card I read 20Mbits but I also read Class 6.. anyway.. it works!
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
