Audio problem with downconvert on HDSDI at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 600/700/800 Series Camera Systems
GY-HM6xx, HM7xx and HM8xx ProHD camcorders & decks.
Old February 4th, 2010, 08:55 PM   #1
Contributor
Hi - I have no problem with the HD-SDI embedded audio when recording hi-def on the HM700 via HD-SDI but real issues with the downconvert to SD.
On Avid via my NitrisDX box the audio is distorted and on the Convergent Design Nanoflash it is unusable (sounds like a sample rate problem) and won't import into Avid at all (sample rate error). The audio recorded in camera is fine.
Can anyone else confirm this issue on their cam?
John Mitchell is offline   Reply With Quote
Old February 5th, 2010, 12:21 PM   #2
I have a problem with 1 of several computers, where it makes a hissing sound on and off, rendering the sound unusable.
This only happens on one of the computers with Premiere Pro - if I use for example Edius, there's no problem. And if I use another computer with Premiere Pro - then there is no problem either.
The computer in question runs 64-bit Windows 7, so that may have something to do with the problem, but untill now I have failed to clearly locate the problem. I even shifted the soundcard on this computer - but problem still exists. So I'm leaning against a OS problem of some sort.
/peter
Peter Erfurt is offline   Reply With Quote
Old February 5th, 2010, 05:58 PM   #3
Contributor
Sorry Peter - I think I missed the connection there? Are we talking about the same thing - downconverted Standard definition material from the SDI port of the JVC GY-HM700?
Old February 5th, 2010, 06:39 PM   #4
Sorry, NO - but then again in a sense yes = sound problems with the output from 700 (!)
But I agree - your problem is not at all the same as mine, but what I'm saying is, that there COULD be issues with the way the 700 presents sound to a computer, hence we have different problems in the NLE systems ??
/peter
Old February 7th, 2010, 09:33 PM   #5
Contributor
Peter I'd say our problems are not at all related. I have had no issue with the sound of the SD cards that record in camera. My problem is entirely related to the HD-SDI port and ONLY on downconvert.
Your problem sounds like a Premiere Pro compatibility issue with the soundcard in that particular machie. It may not be hardware related but could be a software issue such as direct x - keep in mind different software applications call up different decoders to deal with audio and video.
HTH
John
Adorama
(800) 223-2500
New York, NY
New York, NY
Texas Media Systems
(512) 440-1400
Austin, TX
Precision Camera
(800) 677-1023
Austin, TX
VideoGuys
(800) 323-2325
Mineola, NY
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 600/700/800 Series Camera Systems
Banner ads help sustain this site. DV Info Net is sponsored in part by:
1998-2018 The Digital Video Information Network
