Product Demo shot with GY-HM700
Here is a short product demo we shot for a client in France with one of our GY-HM700's. The client will be adding a French voice over later, but the images are pretty nice.
Yes Lou, they do indeed very very very nice. Always tricky to judge anything on the web and a computer screen, but motion and colours look beautiful.
Nice camerawork too. Steve |
Thanks Steve. What I noticed is that the embedded video has a bit of a "strobe" to it. The actual video (or even the one on Vimeo), is much smoother.
Great work Lou !
I noticed a white spot (8 Seconds) did you saw it ? can you tell us your setting? did you have the Canon or Fujonon lense ? Thanks Mike |
Hmm, no I didn't see a white spot. I wonder if it's just another computer anomaly? Like I mentioned earlier, the video looks different here than it does on the actual Vimeo site, OR the full resolution video itself. Who know what kind of compression they use.
We were using the 17X Fujinon lens on the camera with a polarizing filter, I think the detail was dialed down to -7...I think. |
2 Attachment(s)
Less details so you got less noise right ?
About the white spot have a look here Lou Mike |
Mike, you may have discovered an issue with our camera. I'll have to look at some other footage and try to determine what's causing that white spot...I don't think it's dust on the lens.
A dead pixel?
It looks like it could be a dead pixel. It happens from time to time on my 700. There is a quick fix in the "engineer" menu. If your dealer thinks thats what it is I can pass along the instructions on how to do that.
Calvin:
I'm going to call the dealer today. Question though...could it hurt to go through the dead pixel procedure anyway just in case? |
Hi Lou I knew I was right ;-)
I used to have one two :-( but it's easy to fix folow this instrcutions and it would be fixed quicly !!! .WARM CAMERA FOR 30 MINUTES .SET CAMERA TO 720 60P .POWER-UP PLUS PUSH THE DISPLAY BUTTON AT THE SAME TIME WHILE CAMERA IS POWERING. .PRESS....MENU PLUS FOCUS ASSIST BUTTON AT THE SAME TIME .ADVANCE MENU WILL APPEAR .SCROLL TO ADVANCE FUNCTION .PUSH: SET BUTTON .SCROLL TO THE WORD: PIXEL COMPENDET .PUSH: SET TO EXECUTE .NOW: PHYSICALLY EXECUTE THE PROCESS .EXECUTING WILL FLASH THEN STOP NO MORE DEAD PIXEL(S) |
