Settings for the Sony look at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old May 4th, 2010, 04:17 PM   #1
For my old JVC DV5000, there was a tutorial on this site for setting the image to look more like a Sony image. Is there one does one of any settings I can use for the HM700 to achieve the same look?
Zulqar Cheema is offline   Reply With Quote
Old May 11th, 2010, 12:48 AM   #2
It is difficult to quantify the "Sony" look. Can you be more specific on what camera or camera profile you would like to match or provide a link to the tutorial you referenced? There are some recipes in this forum for specific looks that can be achieved with the HM700.
Tim Dashwood
Old May 11th, 2010, 06:50 AM   #3
Thanks Tim, The articles were by Louis Bruno , secrets of the GY DV5000, I get posts on a doc, see below..
Secrets of the JVC GY-DV5000: Sony-look
________________________________________
Top level DV Shooting JVC GY-DV5000
Author: Louis Bruno
Publishing date: 18.09.2003 02:35
Lou Bruno, our JVC GY-DV5000 guru, keeps 'em coming. Now he has something new up his sleeve. This time not a dark hidden secret from the depths of the menu, but a way to make the image of the JVC GY-DV5000 look like it was shot on a Sony camera. Many cameramen like this look or are used to it, so here it goes!
GY-DV5000 camera controls
Sony cameras have a certain feel over the images they produce. They tend to have a warm feeling over them, emphasizing the reds in your picture, while still keeping a fresh, almost blue-ish tint over them. This sounds strange when you read it, but once you've seen a Sony-picture, you'll recognize it anywhere.
The JVC has a totally different feel to it. These settings below will help you mimick a Sony look. Try it and enoy it. If you can improve it, feel free to post in our forums.
These are the settings to go with, all to be made in the CAMERA PROCESS and ADVANCED CAMERA PROCESS menus.
• MASTER Black Level +3 - NORMAL
• Detail +1 normal
• Knee 80% 100%
• SKIN Detail ON
• Color Matrix WARM*
• Gamma -1 normal
*You can also use a 1/2 WARM card or a Tiffen WARM filter (812) but you have to white balance then place the filter on the lens. NEVER WB with the filter set to ON.
By crushing your blacks too much with the compress switch it affects the overall picture. The -1 or even -2 GAMMA does the job slightly and increases color saturation. The WARM setting introduces a somewhat SONY red. Also, if you use a better lens such as a 19X Canon or 20X Fujinon, you will see a closer Sony-type look.
Lou Bruno
Hope that is enough to convert
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
