Cant stop seeing Blue at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old August 20th, 2010, 01:24 PM   #1
Hey everybody, I have had my HM700 for about a month now, and have been shooting basically everything I can get in front of it. I have a whole bunch of different scene files saved, a few of which I have from here, and no matter what I do, everything seems to have a blue tint. I do shoot with the ND filter on sometimes, and I understand how that effects the color, but would something like black toe, or stretch have an effect on the washed out blue images I seem to be getting?
Thanks in advance!
Stephen Dougherty is offline   Reply With Quote
Old August 20th, 2010, 02:35 PM   #2
Examples?
Is there any way you could post some freeze frames or video for us to look at?
Adam Grunseth is offline   Reply With Quote
Old August 21st, 2010, 05:55 AM   #3
Stupid question, but did you check your white balance ?
Maybe you are in 3200 K so all your scenes will have blue tint.
Best regards
Mike
Mike Laisney is offline   Reply With Quote
Old August 21st, 2010, 09:13 AM   #4
Here is a screen shot,
and after checking the white balance, I think you might have been correct, as of right now its not 3200k but It very well could have been.
Old August 21st, 2010, 10:46 AM   #5
Yes it was your white balance :-)
in 5200k it will be more yellow tint :-)
Old August 21st, 2010, 11:06 AM   #6
I just went outside and shoot some more stuff, ill post some screens. It looks much better now!
Old August 21st, 2010, 12:04 PM   #7
Old August 22nd, 2010, 11:43 AM   #8
You need one of these. 72mm Expodisc "Neutral". I use it every day and I get fantastic results. It's magnetic and pops right on the existing uv filter.
Just do a reading and remove it. If conditions change just pop it on again and set a new reading. Easy as pie....
http://www.bhphotovideo.com/c/product/358073-REG/ExpoImaging_EXPOD72_ExpoDisc_72mm_Digital_White.html
Steve Nordahl
Bethlehem, Pa.
Steve J. Nordahl is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
