First time card Problem...need help at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old October 22nd, 2010, 08:50 AM   #1
Hi, I'm been using my HM-700 since april and have not had a single problem with it until today. I've been using Delkin devices 32GB cards and have never had an issue of any kind until today. I filmed a 30 minute school play this morning and everything seemed to be working perfectly. The record light was on, and in my viewfinder, I was seeing the time code progressing, as well as how many minutes were left on the card. It started at 111 minutes and when I stopped, it was 86 minutes. when i got home and put the card in my reader, it said "no files" when i opened the folder. I was horrified! I then put the card back into the camera and pressed the media button....there were no files...and yet the on-screen info indicated that footage had been shot and that there was ionly 86 minutes left on the card. (The card had been formatted before the shoot). I put the card into my HM-100 and the same thing happened. When i set the camera to media and looked at the viewfinder, no files showed up, and yet it indicated that about a third of the card's storage had been used up. Can anybody offer some assistance. I need to know if the footage is really gone or if not, how i can salvage it. Thanks so much in advance.
David Medzorian is offline   Reply With Quote
Old October 24th, 2010, 02:04 AM   #2
Have you tried the restore media option in the camera menu.
George Kilroy is offline   Reply With Quote
Old October 24th, 2010, 05:36 PM   #3
Restore is not highlighted....only format. i know there's something there...the camera says so. Is there something else in the menu that I have overlooked?
Old October 25th, 2010, 05:07 PM   #4
David,
Just throwing this out just in case you haven't already checked. The card has a write protect slider, is it off?
Also on your PC/Mac have you changed the setting that hides hidden files? If there is something on the card and it is hidden, I'd be curious what the file & extension is.
Steve
Steve J. Nordahl is offline   Reply With Quote
Old October 25th, 2010, 06:45 PM   #5
Steve, much of what you've just said is new to me, in all humility. could yu explain a bit more and tell me how i would alter these settings on my PC in regards to hidden files? thank you.
Old October 25th, 2010, 08:33 PM   #6
David, how do you pull the files off the card?
I've been using a trick of searching for *.mp4 and point to the 'N' drive ( where the card shows up) and then move the mp4 off.
If for some reason I forget to format the drive and the reamaining folders are still there, it will show as if all the MP4 are there when there not.
have you tried a search for *.MP4
John Sirb
Lake Breeze Video
John Sirb is offline   Reply With Quote
Old October 26th, 2010, 05:18 AM   #7
have not tried that (search for .MP4). Could you provide me with some detail as to how you do this? I'd be grateful. thank you
Old October 26th, 2010, 06:33 AM   #8
just up the search window and for the file name type *.mp4. the Asterisk is a wildcard for you don't need to worry about the actual name. then point to the drive letter your card reader comes up as. ( on mine is comes up as drive N:)
then select all and copy ( or move) to your HD. I prefer to do a copy until I verify the files are complete
John Sirb
Lake Breeze Video
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
