HM600 green screen & HDMI/SDI output
Hi Everyone,
Considering the HM600 for both ENG and green screen (talking head on virtual set). 1. Is it true that, though the HM600 has 12-bit 4:4:4 sensors (according to JVC marketing), it apparently only records to 4:2:0, even at 50 mbps, even with the new firmware? 2. Does either its HDMI or SDI output offer 1080p 4:2:2 (even if only 8-bit), or is it interlaced, 4:2:0? 3. Has anyone tested, or would anyone be willing to test, the HM600/650 for green screen? Don't see any tests online. Thanks a lot, Tom |
Re: HM600 green screen & HDMI/SDI output
The recorded signal is 4:2:0 on the SD cards. The SDI output is 4:2:2. You need an external recorder to capture that.
Thanks, William, I appreciate your help. Yes, I would capture with a Blackmagic capture card for green screen.
Do you know if it's 8-bit or 10-bit; and can output full 1080 progressive? EDIT: My bad, HD-SDI is only 1080i, so I guess it would not output 1080/60p but would output 1080/30p albeit over an interlaced signal (if that makes sense)? And does the HDMI out have the same limitation? Thanks, Tom |
Let me get with JVC for some answers. That camera is $2995 right now with the $1200 instant rebate applied.
I believe that HD-SDI and HDMI have the same specs regarding interlace. (and yes, 30p is sent cleanly as well as 24P). I know HD-SDI is 10bit but HDMI I am not sure.
