HM100 Wide Angle Converter Footage?
Has anyone shot footage with the JVC GL-V0746U Wide Conversion Lens or the 16x9 Inc. 169-HD7X-HM100 0.7 Wide Angle Converter Lens
If so - please post sample. P.S. I searched the forum but could not find actual footage showing each/either of these. |
here you go
It turns out not to be dust at all, rather manufacturing imperfections on an internal element. The technician told me that some of the glass is not up to broadcast standard. Well, I guess you get what you pay for. Anyone with a JVC adapter care to look through it with a bright light behind? View it at lots of different angles from both ends. I saw what looks like loads of little dust spots. Will be giving the supplier a call shortly with a view to exchanging the lens. If I see the same thing again, time to ditch the JVC and pick up a 16X9 Inc lens.... Cheers, Cotty |
Now I'm really confused. Got my WA back and it looks clean inside. Perplexing. Looks fine now, so maybe they didn't see the dust and cleaned it all off anyway? The apparent imperfections must be miniscule as I can't see them with the naked eye. Maybe I need a drink....
Schneider Optics
Century 46mm HD Series - Schneider Optics Hope this helps, Craig |
Front filter
Has one put a front filter for their JVC GL-V0746U?
Is the 16x9inc converter still available?
http://www.bhphotovideo.com/c/product/621713-REG/16x9_Inc_169_HD7X_HM100_169_HD7X_HM100_0_7_Wide_Angle.html |
Hi Guys,
i used a SONY VCL-DH0758 Wide Conversion Lens, 0.7x with a upsize adapter 46mm to 58mm and it works wonderful. No vignetting. the best on it, also full zoom thru. i cut a piece from the Sony VCL and screwed on the the adapter and fixed it with little bit of glue. i loved my 60$ Lens. thomas |
