February 10th, 2011, 11:26 AM | #1 |
JVC GY-HM100 and tripod
I am new to this forum and proud owner of HM100. I wonder if you turn the OIS off when you use JVC GY-HM100 and tripod ? When I use my Canon XM 2 (GL2) I always turn it of. Canon strongly recommend that. I do not know why. Maybe the OIS can not handle well small vibration from the tripod ?
FB |
February 10th, 2011, 12:21 PM | #2 |
Hi Finnur,
It is standard practice to turn the OIS off when on a tripod with any video camera. If you leave it on, it can make your pans or tilts jump at times. Basically, the OIS is "fighting" your attempts to pan smoothly on the tripod. It can be useful at times - e.g. if you are trying to shoot a static shot at full telephoto without panning or tilting, but generally it should be turned off. |
February 10th, 2011, 12:39 PM | #3 |
Thanks for answering Mike, I was thinking the same. I made some tests with pans and you are right. I also found that a tiny gust of wind, causing vibration on the tripod (not visible) and I was not touching the tripod, made visible strange shake with OIS on. Like OIS was struggling to compensate for something it was not designed to do.
March 10th, 2011, 04:16 AM | #4 |
Re: JVC GY-HM100 and tripod
Hello Finnur, I use my HM100 up a stepladder on a platform I have rigged up, this is so that when I go to shoot a band or play I don't have to ask for a table to stand on. I leave the OIS on because there is movement in the ladder. I have never had any problems because the OIS on the JVC is superb
March 10th, 2011, 01:36 PM | #5 |
Kevin, I am as many other confused about this topic. I my self have not noticed any difference. There is a difference between real world and theories.
March 10th, 2011, 02:44 PM | #6 |
This isn't a theory! OIS _can_ affect the smoothness of pans and tilts.
It is not universal; sometimes you notice it, sometimes you don't. But at some point OIS _will_ create a nasty jump in a smooth pan that you can't re-shoot, or don't notice 'til you get back to the edit suite. It's not specific to this camera, or JVC. It's one thing having a camera locked off at the top of a ladder - if you don't move that much, then it'll be fine (and OIS will probably help a lot). Searching a bit on these forums should turn up more information about this. |
March 11th, 2011, 04:22 AM | #7 |
Hi MIke
My shots are steady for the most. Yesterday I used a very slow pan and I could see some stuttering. Then I turned the OIS off and made another. There was no stuttering, which confirms your statements. So in stead of google any more I think I will follow your advice. Tripod - no OIS. Handheld - always OIS. |
