Go Back   The Digital Video Information Network > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM Series Camera Systems
GY-HM 100 & 700 series ProHD tapeless camcorders & decks.
Old April 8th, 2009, 02:24 PM   #16
Yes. The workflow for FCP and .MOV is super simple.
1. Copy files from the SDHC card to the hard drive. (You can skip this step if you're in a real hurry.)
2. Drag and Drop files into FCP bin. (There is no need to use "import" menu or Log & Transfer)
3. Start editing.
If you are editing into a new sequence FCP6 will ask you if you want to set the sequence to the same settings as the source clips. I recommend doing this but then go to Sequence settings-->Render Tab and set the render codec to ProRes422.
Old April 19th, 2009, 01:45 PM   #17
I know these tests are not for testing the camera.. but... can you tell us something more now.... ? I bought a HM700 and I am finding some noise. Also the 17x Fujinon lenses seem to have quite a magenta/green fringe. Were you able to test it? I'd love to see some footage done by a professional DOP. Thanks, Marcello
Marcello Mazzilli is offline   Reply With Quote
Old June 19th, 2009, 01:42 PM   #18
Just tried downloading XDZP1 XDCAM EX Clip Browser from the UK site but you have to register and there appear to be problems on their registration page.
Dave Tyrer is offline   Reply With Quote
Old June 23rd, 2009, 11:53 PM   #19
[QUOTE=Dave Tyrer;Just tried downloading XDZP1 XDCAM EX Clip Browser from the UK site but you have to register and there appear to be problems on their registration page.[/QUOTE]
I think you need to compulsorily fill out the details marked in asterisk on the registration page. The phone number entries needs to have - between or it does not go ahead... That's the little problem I faced. Hope that solves...
Amir Jaffar is offline   Reply With Quote
Old June 26th, 2009, 01:38 PM   #20
Thanks Amir...I did all that but still no joy. I did however manage to find it elswhere. Just got to try and load the .mov files into Vegas now.
Old June 26th, 2009, 01:54 PM   #21
I've managed to play the MP4 files in Vegas 9 Pro demo and I'm just trying the MOV files. Is there any difference in using either type ?
Old July 9th, 2009, 04:48 AM   #22
Vegas and MOV files
Did you have any luck in playing back the MOV files in Vegas 9? I tried and got the audio track only and the video track did not appear when I dropped the file into the timeline.
Tracy Foust is offline   Reply With Quote
Old July 9th, 2009, 05:05 AM   #23
In order to play MOV files in Vegas you need to install this codec
Calibrated{Q} XD Decode
It's a demo and has grey stipes across it but at least you will be able to play the clip.
Old September 16th, 2009, 10:10 PM   #24
Contributor
Avid compatibility
Thanks Tim for uploading the clips..
Complete succes with the MP4 files. Took the clips into clip browser and exported them as NLE compatible MXFs
I could then import then in the same codec (no transcoding involved). The only hiccuop was the 1080P24 file whcih is actually 1080P23.976 (Avid has both 23.976 and 24) - once i opened the correct type of project Avid could import the clip with no problems. I haven't tried AMA yet as the clips are all of varying speed and raster so it woud have been just one clip per project but i imagine it would work.
So far no success with the .movs as I don't have the third party Windows codec. However I have a Mac here with the latest FCP and I'll see if I can import directly to Avid on that.
John Mitchell is offline   Reply With Quote
Old September 17th, 2009, 02:24 AM   #25
Contributor
Avid (cont)
On the Mac with FCP I can import the .movs directly into Avid.
Frame rate does not seem to matter with the QTs (as opposed to the MP4s) so I could import all the over cranked and undercranked footage straight into a 720P25 project automatically conforming it to that frame rate.
Remember Avid ties the format to the project where as FCP is format agnostic. A project in FCP can contain multiple formats, a project in Avid may contain only one. By format I mean raster size and framerate, not codec.
In summary you can get all types of files that the JVC GY-HM700/100 generates into Avid. If you are on a PC you will need to shell out about $100 to buy a 3rd party decoder for the Quicktime .mov format, although I suspect eventually QT will support them directly or perhaps with just the MPEG2 component loaded. You will need Sony's free clip browser to re-wrap the .mp4s into mxf format but that is an exceedingly quick and easy process.
If you are on a Mac and you have FCP 6.xxx installed you already have a decoder installed and can import the .movs directly into Avid.
In summary these cameras have none of the problems of hte previous HDV generations had with Avid.
Old October 2nd, 2009, 11:28 AM   #26
when you converted the mp4's for use in Avid, did it retain the original time code upon import?
KevMcCarthy is offline   Reply With Quote
Old October 27th, 2009, 07:21 PM   #27
Contributor
Sorry Kev - I wasn't subscribed to this thread but yes it did. It will also preserve metadata that is compatible.
  You are here: The Digital Video Information Network > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM Series Camera Systems
Google
