JVC KA-MR100G SxS at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old May 12th, 2009, 11:42 AM   #1
JVC KA-MR100G SxS
I have just bought the JVC HM700 camera with the sxs recorder fitted. JVC emailed me the firmware to get it up and running and told me over the phone how to do it. However I had already bought the MxR expresscard 34 reader for it, hoping to use the SDHC cards instead of the SXS cards but the MR100G does not recognise the card while inserted. I'm wondering is the MR100G only set-up to recognise SXS cards. Can anybody else out there help me? Greg.
Gregory Murphy is offline   Reply With Quote
Old May 12th, 2009, 02:49 PM   #2
Sponsor: Westside AV
I believe the issue is that the SDHC cards work through a USB interface, Sony had to update firmware on the EX1 to be able to use their hard drive and that is what enables the use of SDHC card adapters too.
So JVC will probably have to issue a Firmware update as well to use the USB interface.
Old May 12th, 2009, 05:54 PM   #3
If you want to use SDHC cards with the HM700, can you not just put them straight into the SD slot of the camera itself?
Old May 13th, 2009, 09:15 AM   #4
ka-mr100g
I would like to use an SDHC card in the SXS recorder as a backup of the SDHC card in the camera. Its not worth buying a SXS card just for that so an adapter would be very useful and a lot cheaper.
Old May 14th, 2009, 05:01 AM   #5
Great idea.. let us know if you find something that works with it
M
Marcello Mazzilli is offline   Reply With Quote
Old May 15th, 2009, 01:52 AM   #6
IIRC, the SDHC adaptors work with the EX line only because of the adaptions built into these cameras for the Sony PHU-60K disk recording device which is strictly a USB device.
If the PHU-60K does NOT work with the JVC's SxS (which I think is the case), then I would also surmise that the JVC will NOT take the SDHC cards as its SxS does not have the USB capability that makes the 'magic' work.
EX1 x2, C100 --> FCPX & PPro6
Old May 18th, 2009, 05:48 AM   #7
Jvc ka-mr100g sxs
Does this mean that there is no adapter that will work or would a PCIe compact flash adapter work?
Old May 18th, 2009, 08:46 AM   #8
It only means that the current EX1-style SDHC adaptors work via USB. From then on, we get into conjecture.
IIRC, it's moot because the new JVCs record QT to SDHC and the SxS is just an add-on.
Old May 18th, 2009, 12:12 PM   #9
Normally comes KA-MR100G SxS with a 8 GB SxS-Card, says the JVC-people to me.
Isn`t it?
Eric Deyerler is offline   Reply With Quote
Old May 18th, 2009, 12:15 PM   #10
Originally Posted by Eric Deyerler View Post
Isn`t it?
I think wires are getting crossed. SxS in SxS slot - no problem. SDHC in adaptor in SxS slot - unresolved, and risky if you're betting the farm on this.
Old May 29th, 2009, 11:51 AM   #11
SDHC cards in SS Module
Since you are looking to use SDHC cards in your SxS module you must not need the module at all. Sell your module and purchase several SDHC cards and HOT SWAP them one at a time on the fly. Less equipment ... the KISS theory.
Ron Edwards is offline   Reply With Quote
Old May 30th, 2009, 09:50 AM   #12
Ron, I think the reason he wants to do this is to take advantage of recording to both media systems at once, and keeping both media sets at a reasonable price.
Generally, I suspect that this backup approach is not worth the trouble. With quality tested media and proper handling, the SDHC should have an extremely low failure rate - much better than tape for instance.
The converter and added operator/handling of this backup is more likely to introduce issues than actually ever save a piece of footage.
The biggest advantage would be if 2 people had to walk away from ashoot with clones of the footage. 10 minutes with a laptop would usually cover that better.
I'd be curious to know if a way to make it work (SDHC in the SXS box with converters) does come to light.
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply With Quote
Old June 13th, 2010, 05:51 AM   #13
The MEAD-MS01 and MEAD-SD01
Sorry to revive an old thread but I have been wondering about the new adaptors that Sony have released earlier this year.
Does anyone know if these adaptors will work with the KA-MR100G?
Sony : MEAD-MS01 (MEADMS01) : Consumer Memory Stick Adaptor for SxS
Sony : MEAD-SD01 (MEAD-SD01) SDHC Adaptor for SxS
Daniel Marr is offline   Reply With Quote
Old June 14th, 2010, 06:28 PM   #14
No adapter will work with the KA-MR100G because the internal connection that made the adapter function in the EX1 (USB) does not exist on the HM700/790.
Tim Dashwood
Old June 15th, 2010, 03:08 AM   #15
Ok. Thanks for the clarification Tim!
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
