sound diaplay at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old May 29th, 2009, 10:59 PM   #1
sound diaplay
the mic level display in the camera is witout numbers.
does anyone know where is th 0 parameter?
Amos Rafaeli is offline   Reply With Quote
Old May 30th, 2009, 09:22 AM   #2
Please note whether you are asking about the HM700 or 100.
Neither have numbers (never seen them on the VU meters). The following is for the 700, but I suspect the 100 is similar in the menus. - RTFM ;^)
These audio levels (mic or line) have menu settings which enable you to set the point in which the bold marker you use for setting standard level will be.
Note that with digital recording, we don't use 0 for a standard level. Levels are set much lower, because digital self noise is very low, but distortion when over-modulation occurs is much worse. The Audio reference level can be set to -12 or -20 depending on how conservatively you want to monitor your levels. This doesn't affect the levels themselves, which would be the same either way with a manual setting, merely the way you monitor them. A more experienced closely monitored level could be higher - a set and forget approach is probably better higher. Just remember, a red led probably means distortion is occurring, not the gentle compression first that analog recording had.
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
