HV20 + Extreme at DVinfo.net
Alternative Imaging Methods
Old November 1st, 2007, 10:40 AM   #1
HV20 + Extreme
Finally got the rig setup:
HV20
Letus Extreme
Cinevate 45mm carbon rails
Cinevate Mattebox
Libec LS-55 tripod
I was able to mount everything perfectly level and balanced; no front or rear heaviness at all.
Next up: Test footage...
Leo Versola is offline   Reply With Quote
Old November 1st, 2007, 01:36 PM   #2
What have you used to raise the HV20 so high?
Philip Bloom
Old November 1st, 2007, 03:32 PM   #3
I think he just change the 5/8 rod to a longer one instead of the standard 5/8 rod that comes with the Cinevate rail set.
David Chia is offline   Reply With Quote
Old November 1st, 2007, 08:58 PM   #4
Hi Phil,
David is correct... Dennis Wood of Cinevate gave me a 6 inch post in addition to the standard 3 1/4 inch post for the camera baseplate. The post is actually 5/8 inch tubing you can buy at most hardware stores.
I knew I would need a longer post in order to raise everything high enough to fit into the mattebox at its lowest height so I just asked him to include it with my rails and mattebox.
Cheers,
Leo
PS: How's the Extreme testing coming along?
Old June 21st, 2008, 10:48 AM   #5
Hi Leo, where did you get the step down ring to fit the hv20? BH?
Alex Ponce de Leon is offline   Reply With Quote
Old June 22nd, 2008, 10:33 PM   #6
If you have a 72mm ring on the Extreme, you can use a pair of step rings to make the jump to the HV20/HV30 43mm threads.
52mm to 72mm ring
and
43mm to 52mm ring
That's what I use and they work great.
Aaron Pinto is offline   Reply
