Got my Letus35 2 weeks ago, not what do I do at DVinfo.net
Alternative Imaging Methods
Old November 19th, 2005, 11:16 AM   #1
Okay what do I need to attach my lens onto the adapter.I did get the step down ring to attach the adapter onto the camera. Now need to know what I need to attach the lens onto the adapter
Xeaver Dupre is offline   Reply With Quote
Old November 19th, 2005, 11:34 AM   #2
Okay, I kept reading, you can only attach a 58mm lens like nikon,am I correct or not.
Old November 19th, 2005, 11:41 AM   #3
Images: 1
The Letus should come with either a Nikon or a Canon FD mount as one end. Those flanges you see there are where the lens goes on. No, you can attach many different kinds of lenses as long as they have the mount you ordered with it--i.e., if you have the Nikon mount, you can attach a 50mm prime Nikon lens, or a 35mm prime Nikon lens, or a 50-200mm zoom Nikon lens, or whatever else comes with a Nikon mount--the whole purpose of the Letus is to give you freedom to use the wide variety of SLR lenses that are available.
BenWinter.com
Ben Winter is offline   Reply With Quote
Old November 19th, 2005, 11:50 AM   #4
okay, so I can use any lens as long as i order a mount with it.
Old November 19th, 2005, 11:52 AM   #5
Images: 1
Nooo--the lens has to be compatible with the Letus and therefore must have the same mount type as the Letus. "Mounts" aren't anything extra--they're simply part of the lens assembly. Did you order the Letus35 with the Nikon mount or the Canon FD mount? If you ordered the Nikon mount then any Nikon lens (which therefore has a Nikon mount built on it) would work.
BenWinter.com
Old November 19th, 2005, 11:54 AM   #6
Okay my adapter has a Canon FD mount, I'll just use a canon lens
Old November 19th, 2005, 07:02 PM   #7
I'm just wondering, What's the step down ring you used for the Letus35 to your camcorder? I'm new to this I don't know what the measurements are for the Letus35.
Kawai Sin
www.rollingedit.com
Kawai Sin is offline   Reply
