Tape jumps
We logged some footage from a wedding and this particular tape jumps a frame and seems to be timed the same time each time. Probably a bad tape because we have used the same camera after without any problems. So....the million dollar question is: Is there anything we can do in post to correct this?
Thanks, John |
Anyway, I am wondering if it isn't an ongoing problem... |
If I understand your 'jump' correctly, I've seen this on the Maxell Red tapes, the one's from Sams Club. I wish I knew what it was, but who knows. The issue is rare with me, rare enough that I know better than to only run one camera at a wedding, so we can edit around it.
The tapes I have been using is the Panasonic AY-DVM63PQ. The jump occurs throughout the entire tape. It's as if you cut one frame out causing the image to "jump" ever so slightly.
John |
I never had the problem with the Sony HD tapes, but they are so darned expensive, I tried these instead. I'm actually going to check and see if there is a grade inbetween to try. That is after I finish the case of these I just bought! |
Steve: Didn't notice anything on the LCD. We are trying a recapture to see if that might solve the problem.
Ive had the similar problem happen on a rare occasion while digitizing. I think it could be a problem with "dirty" heads. When I run a head cleaner and try it again it clears up.
Hope this helps! |
Thanks Heather. We captured the tape again and cleared up the problem. Strange.
