Dubbing DVCPro to MiniDV with Adapter? Is it possible?
Hello All,
I have tried multiple times on multiple decks to dub from DVCPro to MiniDV on a DVCPro deck with the MiniDV tape in a "DVCPro to MiniDV" adapter. For some reason I am UNABLE to record on the MiniDV deck. I have checked the record safety tabs on both tapes, and still nothing... Is this even possible? Any help is appreciated! Thanks! |
You mean you are trying to record on a miniDV tape, but the deck is a DVCPRO deck?
It may not be able to do that? The formats are similar but not the same. |
Little help here??!
I have the AJ-D455 Panasonic DVCPro (25) deck. When I connect it to my Avid and use a MiniDV tape with an adapter that fits into my deck it records MiniDV fine. I use the same deck to reverse the process, digitizing something that was shot on MiniDV-- also fine.
DId this answer your question, it was hard to follow. |
I may be wrong, but I think some of the older DVCPRO decks will not record in standard DV, even though they may play it back. So even though you could get the machine to physically accept the tape, and possibly even start rolling, they would be recording either a DVCPRO signal onto the tape (which would not play back on a DV deck or camera), or nothing at all
I've always understood it couldn't be done.
I'm sure others here can better describe the difference. |
Er... I think the HVX200 can record onto miniDV tape (and not DVCPRO tape).
If you're dealing with data (recording onto P2), the DV and DVCPRO codecs are the same thing. 2- DVCPRO on tape has a wider track pitch. More tape is used to store the signal / the tape is played back faster. The wider track pitch allows for linear editing from what I know (frame accurate). http://www.adamwilt.com/DV-FAQ-tech.html#DVformats |
