Capture issues in Windows 7?
Anybody here using Windows 7? I just installed it the other day and the only issue I've had so far is that I absolutely cannot capture from my JVC deck (CU-VH1). The computer recognizes it - it shows up correctly identified under "Devices and Printers" but when I try to capture in either Adobe Premiere or Sony Vegas I get a "Device not found" message.
I can still capture on my laptop (Windows XP) and move the files over to my edit machine, but I'd rather find out there's an updated driver download available. |
Chances are that any card manufacturers will not be working on an updated driver for Win 7 until the goal posts are firmly cemented in to the ground. Something like the Win 7 software going "gold" and being shipped off to manufacture.
Anything else would be financially foolish for the company. Video workflows are finicky and demanding as it is. Andrew |
Windows 7 has shipped to manufacturing. I'm running the RTM version which was released last Friday.
I have found a few others online that have the same problem, as well as a few solutions, but none have worked for me so far. |
Oh wow. That was quick. Why ... it was only just the other day that it was in beta.
Andrew |
Since Windows 7 will be available in stores this week, I'm sure others will have this problem, so I thought I'd post the solution that worked for me and many others.
The problem is that Windows 7 apparently installs the wrong driver upon detecting a firewire port. Step-by-step, here is the solution: 1. Go to Device Manager and click on IEEE 1394 Bus host controllers 2. Click on the device listed underneath this heading. In my case it was Texas Instruments 1394 OHCI Compliant Host Controller 3. Right click this device and select 'update driver software' from the shortcut menu 4. Then select the option 'browse my computer for driver software' 5. Then select the option 'let me pick from a list of device drivers on my computer' 6. This then gave me three drivers to pick from (make sure the 'show compatible hardware' checkbox is ticked) 7. Select the driver named '1394 OHCI Compliant Host Controller (Legacy)' 8. Install driver No reboot is necessary, capturing via firewire should now work. |
Thanks very much Chris. Worked right away.
Actually, that's not the first time Windows auto-installs the wrong driver. There was the same sort of issue for wi-fi adapters under Windows XP.
(Answer was to install the driver from the manufacturer's CD prior to installing the hardware adapter. Or else ...) Andrew |
Sorry, posted to wrong item....
