-   The Long Black Line (https://www.dvinfo.net/forum/long-black-line/)
-   -   stripe all the way ! (https://www.dvinfo.net/forum/long-black-line/33771-stripe-all-way.html)
Paul Juhn October 21st, 2004 04:45 AM
Hi,
I am using Canon XM2(GL2) and PPRO1.5.
I was rewinding and playing back the coverage that I just finished capturing.
I was completely shocked when I looked at the LCD screen while playing back the original - the screen has got all stripes about 10.
I thought it was going to be like that only at the beginning but it was like that about 10 minute and then back to normal.
What happened to my tape?????
I just suspect that while I was playing with AVI file PPRO put some images back on to the tape.
But is this possible? when I did not do "export to tape"?
Any experience?
Yes I am a novice.
Peter Jefferson October 21st, 2004 05:22 AM
2 things about tape
whenever u use a new brand of tape, make sure u run a head cleaner BEFORE the change. This way you dont get cross contaminants on your head from different tapes which use different lubricants.
secondly and i know its tedious, FF then RWD the tape/s BEFORE you use them. This allows the camera to set the slack/tension according the cameras own motor drive.
It also loosens the tape from the spool.
SOme tapes have been on shelves for a very long time, this can c
cause the damage your experiencing.
I use 2 dvx100's and i use this routine before every job and i have NEVER had a drop out. (the DVX has niggly heads so thats saying something......)
Paul Juhn October 27th, 2004 04:16 AM
Thanks for the advice what about a deck?
I was using SONY tape and I am using JVC...
I never did head cleaning and FF and RW.
Which head cleaner do you use?
Paul J
Andre De Clercq October 27th, 2004 05:33 AM
If you see 10 stripes, then one of the 2 videoheads on the drum is (was) clogged. Run a cleaning tape. I have DVM12CL from Sony
