Lost data on dv tape?
Our company tapes primarily outdoor events, using gl2s that were recently serviced. On reviewing the tapes at the end of the day recently, we discovered that most, if not all of the data is no longer there, even after the videographer saw some of the video during the day when reviewing the tape. There was no blue screen since we black out the tapes for re-use. No video can be seen after rw or ff, just the audio and black video recorded before re-use. It's as if the recording button was never pushed but that is not possible since there is a constant record/pause, record/pause, etc.during the shoot. This happened on 2 different gl2s at 2 different events and three different tapes. We also put the tapes in other dv cameras but still no luck in finding the video. Can video be lost once it's recorded on the tape without recording over it and is it possible to retrieve it? Need help since we can't depend on the camera if it's behaving like this.
Re: Lost data on dv tape?
2. However, skip back to the previous question. If the black and audio is still on the tape when played back, no video was or can have been written to the tape, else the black/ audio would be gone. Fingers a tape write problem, possibly associated with the recent service, cable not connected/ loose, take your pick of options. 3. Back one more question. Using HDV, the BSOD is best reckognised by the fact that video can be seen during FF or REW, but PLAY just produces a blue screen. This is due to the way HDV is handled in the electronics and how it reassembles frames and GOP's. DV is a different kettle of fish, though I must admit, if you can see video during FF or REW and Black in PLAY, now you've got me. 4. Back to the first question/ comment. If the videographer saw video during the day in PLAY mode and THAT segment is now BLACK, you've had a visit from Lucifer himself, because I can see no way that is possible. Based on what you have said, I can see no other explanation other than there is a problem with the camera's write system (s), if it is reproducable. If thorough, prolongued base testing shows up no problems with the cameras concerned, I can't see anything else but operator error of some sort. If the above testing does show up a problem, whomever did the recent service needs a bit of a talking to. Best I can do at the moment. CS |
Tom that is really unusual.
If it happened on just one camera, it will probably be camera fault, but on two! The common denominator here seems to be the servicing of both cameras prior to shooting. Did you "black" the tapes in these cameras and if so, was it done before or after the servicing? If both cameras have recorded sound, then it seems that whoever has serviced them has made the same mistake on both cameras in relation to recording pictures. Record heads out of alignment? Did you shoot in HDV or DV (not familiar with your cameras). If you recorded in HDV, they won't play back in DV, which you have mentioned. Have you tried recording something again, using both cameras? Peter |
Are you using the camera as the capture deck when you upload it to a computer?
I had a similar problem, but when I used the camera as a deck I recovered all the video. |
