A Low Light Trick
In really low light, when shooting stills with flash, there definitely are times when it is difficult to frame on the LCD. I thought about making a "sports finder" of some sort, but found a simpler solution.
I turn the LCD so it is facing up and parallel to the lens axis. (There is a seam on the front of the camera where the chrome of the LCD hinge meets the gray upper body. I line that up with the middle of the front edge of the LCD). I then put the back edge of the LCD to my eye and sight along its top (the screen), making sure that I am seeing it quite flat, not tilted up or down. I then put the center of the desired picture right at the apex of the angle made by screen and body and shoot away, using the wide angle zoom position. It sounds more complicated than it is, and works well without any extra equipment. For shooting objects that are close, some allowance for parallax is needed, but I found that a little practice is all that is required. |
or a laser pen for aiming?
Very interesting idea. |
Luis |
I have in fact mounted an air rifle "laser" sight on a still camera with a 12x lens which worked well for pointing at wildlife.
I don't think it would work well with the HD1 because the flash would be open when you really need it and there isn't any other useful place to put it. The point of my "trick" was that you really don't need any extras to solve the problem I was having. |
In addition to the flashing red warning light above the door to the lab, which was turned on anytime the big lasers were powered up, we had a sign posted on the door: "WARNING: Do not look directly at the laser beam with remaining good eye!" ;) |
