Shooting with the d7k nikon to have better color grading options
Hola,
i read everywhere thecanonists shoot a lot of FLAT stuff to have better control on the grading in post....... So what are your thoughts about that? Any d7000 users have any suggestion for us? Thx a lot |
Re: Shooting with the d7k nikon to have better color grading options
It's called TassinFlat and you can find out about it here:
Shoot flat on your Nikon D7000 and then edit flat in Final Cut Pro, grade in Color Alternatively shoot in the neutral picture style and expose correctly. Either way the bigger barrier for grading will be the 8bit color than the mode you shoot in. |
Wow, so Nikon is what we were waiting for!
thx |
Assuming the sensor has a wider range then the encoding allows, would you not make better use of these bits by grading before encoding?
I shot with super flat/advanced flat/cinestyle variants... and in the long run I get it as close to the final product as I can in the camera. Saves time. If you want flat footage thats your call but I find it an unecessary step anymore if you can get it in the camera.
It is best to transcode into a higher bit-depth format so that you can have more room to grade without introducing banding. This process interestingly generates colors that were thrown away or didn't exist in the original capture improving your overall quality. Quote:
More succinctly shooting flat and then post-processing saves us time and gives more room to be creative in our work. |
Question:
where can i find the TAX FLAT file to put on the camera? Once i set This superflat recording to shoot videos then i have to switch to take a picture, i'll have the camera always set to that Flat picture profile and the picture will be very flat or once i switch from video to camera the pictures will be with normal sature profile? Many thanks |
