-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Compressor goes on for ever (H.264 multi-pass) (https://www.dvinfo.net/forum/final-cut-suite/124266-compressor-goes-ever-h-264-multi-pass.html)
Erik Norgaard June 22nd, 2008 02:50 AM
Hi:
I am trying to convert my video to H.264 for vimeo with the settings listed below. Multipass is on, and it seems to be passing the same for ever: That is, at the time of writing, the third pass with out any output generated yet.
I had the same problem when trying to convert to HD DVD H.264 10.3Mbps. Eventually I canceled after some 10 hours converting 32min fottage.
How many times does H.264 converting need to go?
Thanks, Erik
Description: QuickTime H.264 video with PCM audio at 48 kHz. Settings based off the source resolution and frame-rate.
File Extension: mov
Estimated file size: 2.15 GB/hour of source
Audio Encoder
AAC, Stereo (L R), 48.000 kHz
Video Encoder
Format: QT
Width: 1920
Height: 1080
Pixel aspect ratio: Square
Crop to: Center crop for 1.778:1
Padding: None
Frame rate: (100% of source)
Frame Controls: Off
Codec Type: H.264
Multi-pass: On, frame reorder: On
Pixel depth: 24
Spatial quality: 75
Min. Spatial quality: 25
Key frame interval: 24
Temporal quality: 50
Min. temporal quality: 25
Average data rate: 5.12 (Mbps)
Erik Norgaard June 22nd, 2008 03:47 AM
Ok, I finally got some out put at the fourth pass, is this standard?
James Brill June 22nd, 2008 07:58 AM
I have been having problems like that a lot lately with compressor and h.264. I'm not sure what the problem is but recently I had a 6 minute short only take about an hour which is way better than how long it used to take.
William Hohauser June 23rd, 2008 03:13 PM
h.264 is preset for four pass encoding. This is one of the reasons it can look good with a small amount of data for a video file. You can set it for one-pass but the results may be not very good.
A rule with h.264; the larger the pixel dimensions of a file, the longer it takes to encode.
Erik Norgaard June 24th, 2008 05:04 AM
Is it possible to set it to two-pass? Alternative is MPEG-4, but with VBR I can't set max/average bit rate as for MPEG-2 to limit file size. I'm not certain about the bit rate limit for H.264, if this is a constant rate or upper limit.
Coming from MPEG-2 (HDV) maybe the best (as in quality/MB) is to stick with MPEG-2?
thanks, Erik
