Snow Leopard Advice at DVinfo.net
Final Cut Suite
Old August 28th, 2009, 11:48 AM   #1
Snow Leopard Advice
How should I go about upgrading to Snow Leopard:
A clean install or upgrade?
Jason Boyette is offline   Reply With Quote
Old August 28th, 2009, 01:02 PM   #2
I'm a bit of a noob to Mac, only been using it a couple years. But in my experience, upgrades are no problem. (Unlike Windows, where I have never had an upgrade actually work). I just upgraded 10.5 to 10.6 on a partition I don't use very often. Took about an hour. Seem fine. 10.6 is a fairly minor upgrade UI-wise, but apparently they have improved a lot of the interenals.
You might want to make sure all the software you use still works with 10.6 before taking the plunge.
Hank Coffin is offline   Reply With Quote
Old August 28th, 2009, 04:52 PM   #3
If your system disk is several years old, it's a good time to get a faster disk and install SL on it.
The system can then be booted from either new or old OSX.
Don Miller is offline   Reply With Quote
Old August 28th, 2009, 06:40 PM   #4
Clean install, hands down.
FYI, Philip Bloom posted the following on Twitter earlier today:
sony have confirmed that XDCAM software is not compatible with Snow Leopard. Could be a long wait. DON"T UPGRADE!!
So if you do any work with Sony SxS cards, etc that require using Sony's XDCAM software, you've been warned!
Mike Barber
"I'm laughing to stop myself from screaming."
Mike Barber is offline   Reply With Quote
Old August 29th, 2009, 04:06 AM   #5
Based on my blog post: Travelling Matt
BTW, I'll reiterate - MxR works fine, and I'll be keeping SL on the backup machine for now as FCS3 has felt less stable than FCS2 on Leopard.
Interestingly, I've had to recalibrate my MacBook Pro screen for Snow Leopard, probably because it fixes the Gamma bug in QuickTime. It's for reasons like this I'm steaming forward with an Early Adopter approach on this OS iteration.
Personally, I gotta have Bluray, movable markers, souped up Motion and any incremental teeny-weeny stability improvement I can get on SoundTrack Pro which may require hopping between Leopard and Snow Leopard for the time being, but YMMV.
EX1 x2, C100 --> FCPX & PPro6
Old August 29th, 2009, 05:35 AM   #6
You can still use Final Cut's Log & Transfer to import XDCAM footage off an SxS card that's in the EX1 and connected via USB.
Dana Rice is offline   Reply With Quote
Old August 29th, 2009, 07:46 AM   #7
Here's a list of applications and their compatibility with Snow Leopard...
Mac OS X 10.6 Snow Leopard Compatibility List
Aaron Fowler
PMW-EX1 / EOS 60D / EOS 550D / FCS2 / CS4 PP
Aaron Fowler is offline   Reply With Quote
Old August 29th, 2009, 11:42 AM   #8
Thanks for all the info
Gonna finish my last project up and do a clean install next week
(now I have motivation to finish up!)
