Horizontal banding after mpeg render at DVinfo.net
Final Cut Suite
Old September 21st, 2009, 07:31 PM   #1
I recently upgraded to SL and FC7. I wrote down all of my FC6 settings and used them when I installed/setup FC7. I export video from FC as a reference mov and open in in Compressor. I use the same "2 Hour Best" setting that I have always used, but now I'm getting strange horizontal banding from top to bottom. It isn't always noticeable (to people other than me), but you can really see it when the video fades in/out to something else. I've attached a clip. Any help would be greatly appreciated.
http://www.chaddyleproductions.com/H...talBanding.mov
Chad Dyle is offline   Reply With Quote
Old September 21st, 2009, 09:34 PM   #2
Go Go Godzilla
Images: 15
I definitely see the banding against the white-wall in the background that the couple is walking in front of.
This is partly due to low-light noise but you're also seeing interlaced artifacting as a result of the MPEG compression.
It would seem that Compressor 3.5 is more fussy with interlaced artifacts especially with HDV than in the past (could be that it's becoming more bit-rate accurate?) but the only way to compensate is to go deeper into settings, turn ON Frame Controls and make both motion and de-interlacing encoding to "better" or "best". This will drastically increase encode times but it will also produce much higher quality MPEG2 encodes, by far.
Old September 22nd, 2009, 03:10 PM   #3
Robert,
I will run that clip through again with everything cranked up and see what happens. I'm going to check all of my settings from start to finish again.
