Best RAID/Storage solution at DVinfo.net
Final Cut Suite
Old November 19th, 2009, 06:33 AM   #1
Hi all,
Any recommendations for a good, fast, redundant RAID for use with FCP?
Need a few TB and would like to keep it under £1000.
www.mikemarriage.com
Mike Marriage is offline   Reply With Quote
Old November 19th, 2009, 06:54 AM   #2
Hi Mike,
You should forget at the word "best" since that term is very relative and can cost many USD.
I am using two systems, one based on a sonnet tempo and the second with a RocketRaid. Both are connected to external racks with port multipliers what allows me to plug up to 25 hard disks on each card.
I didnt like the Sonnet even if many users says that are top notch i found the RocketRaid much more stable and faster.
Anyway both works good enough as entry level RAID and give you many possible configurations.
Martin Chab is offline   Reply With Quote
Old November 19th, 2009, 10:01 AM   #3
Go Go Godzilla
Images: 15
Mike,
RAID setups vary greatly in physical architecture, speed (both initial and continuous) and cost. There is no "best" setup because system and individual needs vary so much.
There is a ton of information about the various RAID configurations, connectivity types etc. etc. here on the forum. I'd highly suggest using the search feature and spend some time reading up on the wealth of data.
In less than a week a new "how to" website specific to pro AV users will be up which will outline all this information in a singular contiguous source; when it's live I'll ping you back with the info.
Old November 19th, 2009, 10:38 AM   #4
Please ping me as well!!
Jerry Porter is offline   Reply With Quote
Old November 19th, 2009, 12:45 PM   #5
Ping us all!
Paul Shapiro is offline   Reply With Quote
Old November 19th, 2009, 02:47 PM   #6
To be more specific, I just need a need a simple, redundant (3 disc minimum I guess) raid. I was planning on using FW800. I don't want rack mount, just a stand alone desktop as I sometimes need it to be portable but mainly office bound.
I've already read a lot about it is hard to pick a model as such. I've heard good things about G raid...?
Old November 19th, 2009, 03:23 PM   #7
you can't go wrong with g-raid... very good quality stuff. it's expensive, but you do get what you pay for.
if you are looking for something a little more cost effective i have had my eye on the "mercury elite-al pro" it's a desktop enclosure that offers raid 0,1,5,and 10. it will take up to 4 drives and has firewire 800 as well as e-sata. from what i have heard it works well, is quiet, and is very fast.... 240 megabytes read/write a second on e-sata and about 80 megabytes read and write on fw800.
anyone have one of these want to chime in and confirm this... i would really like to know for myself.
anyway,Hopefully it's okay to post a link here...
OWC Mercury Pro Qx2 4-Bay RAID 0/1/5/10 eSATA, FireWire 400/800, USB2 Desktop Removable Bay Storage Solution - up to 8.0TB
http://www.higherdefinitionmedia.com
RED One #6135 "Spartacus"
Andrew Waite is offline   Reply With Quote
Old November 19th, 2009, 03:43 PM   #8
A platform independent article abouts the basics for editing: Adobe Forums: To RAID or not to RAID, that is the...
Old November 19th, 2009, 05:30 PM   #9
Go Go Godzilla
Images: 15
G-Raid setups are "OK" but highly overrated, just as LaCie products are.
If you've only got 3 disks to work with then there's no point in setting up any RAID at all; you're much better off with leaving them as single drives. You'd need a minimum of 6-8 HDD's to really have an appreciable benefit in the cost and efficiency of a RAID.
The article Harm has copied from the Adobe site is a must-read for anyone not familiar with or wanting to bone up on RAID technology and "how to".
Old November 19th, 2009, 08:03 PM   #10
Go Go Godzilla
Images: 15
Originally Posted by Paul Shapiro View Post
Ping us all!
Roger-Wilco.
Old November 19th, 2009, 08:27 PM   #11
I use the OWC 4 bay raid. Simple, inexpensive and built like a tank. Here are two reviews:
Macintosh Performance Guide: Reviews ? Other World Computing Mercury Elite-AL Pro QX2 4-bay Hardware RAID enclosure
OWC Mercury Elite-AL Pro Qx2
I use 4 Hitachi 2 TB drives in a RAID 5 configuration. Generally I use it connected via FW800 to a MBP, but when I want to transfer data faster between it and another drive, I use eSATA via an Express34 eSATA card.
David Sholle is offline   Reply With Quote
Old November 20th, 2009, 06:34 PM   #12
I have been very happy with my Dulce RAID 3 working drive. And will be adding additional Dulce RAID towers this winter.
Dulce Products
Paul Cronin
www.paulcroninstudios.com
Old November 20th, 2009, 06:49 PM   #13
I use LaCie Biggest S2S 2.5 TB. You can get the 5 TB version now for about $1500 US.
Comes with PCI-X or PCI Express card.
3 years now 16 hours a day 6 days a week nary a hiccup.
Justin Ferar is offline   Reply With Quote
Old November 21st, 2009, 05:27 AM   #14
Don't forget about including a full backup.
If your work is important, and you have deadlines, there's nothing like having a full backup of your projects and the media.
The worst I've heard lately is an independent producer who lost an entire season of work because a RAID system failed. The only backup for all this HD programming was on DV tape.
So when you design your workflow, consider the consequences of that system going into complete failure and what would be left in the aftermath.
Dean Sensui
Old November 21st, 2009, 03:33 PM   #15
Great point Dean,
I use:
Raid 3 for working drive.
Internal hard drives for apps and extras.
All drives backed up on Raid 1 removable drives that store off site.
Paul Cronin
Paul Cronin is offline   Reply
