Final Cut Pro 7 Compatibility with Final Cut Pro 6 at DVinfo.net
Final Cut Suite
Old November 20th, 2009, 03:26 AM   #1
I'm considering purchasing Final Cut Studio 3, however I transfer projects quite often between my machine and and my work machine that is currently running Final Cut Studio 2.
What are the issues with this.. is it possible to save projects in a format that both packages can read or once you've upgraded to Studio 3 thats it, no going back?
James
James Blackburn is offline   Reply With Quote
Old November 20th, 2009, 07:29 AM   #2
Go Go Godzilla
Images: 15
That's right; an older version can't open a newer FCP project.
Old November 20th, 2009, 11:42 AM   #3
That's not true. I go from FCP 7 at home to FCP 6. In FCP 7 export an XML of your timeline. This will open in FCP 6 and it will work. This works in FCP 6.0.4
John Sconiers is offline   Reply With Quote
Old November 20th, 2009, 03:44 PM   #4
Go Go Godzilla
Images: 15
An XML transfer is not the same as a self-contained project which holds all the filters and effects, and not all FX transfer between the versions.
If basic cuts/edits/rolls are all you need in the transfer then yes, and XML file transfer works not only across differing versions of FCP but also cross-platform and OS.
Robert Lane is offline   Reply
