m2t 720 24p files down convert to DV at DVinfo.net
Final Cut Suite
Old March 1st, 2006, 11:15 PM   #1
What is the fastest method to convert m2t files from
720 24p HDV m2t to DV Quicktime that can be imported
into a final cut pro timeline with renderless editing in DV?
I use streamclip after capturing HD100U Footage 720 24p in HDVXDV.
But, using streamclip, I can't seem to find the a workable setting
for the downconversion? Alway makes clips the Final Cut has
to render again for realtime playback...
Rob Stiff is offline   Reply With Quote
Old March 12th, 2006, 02:52 AM   #2
One of the tricks with Streamclip if finding the proper settings. I had some problems when I first started using it when I'd try and export to a .dv. I dont have an HD100 but I know that Apple really likes quicktime. Try exporting as quicktime using the DVCProHD codec or whatever you're planning on using in the timeline set quality to best and frame rate to match your sequence. Good Luck.
Jason Varner is offline   Reply With Quote
Old March 20th, 2006, 09:09 PM   #3
what is streamclip?
Efrain Gomez is offline   Reply
