Go Back   The Digital Video Information Network > DV / HD Post Production... and Beyond! > Non-Linear Editing on the Mac
Discussing the editing of all formats with FCS, FCP, FCE, iMovie and more.
Old March 5th, 2007, 10:37 AM   #1
Trouble capturing with external drive
i am using a macbook pro with external gtech drive connected via firewire 800. if i plug my capture camera (cheap canon) into the firewire slot of either the drive or the mac it can be controlled but displays no video and captures nothing.
if i plug it in without the drive connected it captures fine.
H E L P !
Ray Coy is offline   Reply With Quote
Old March 6th, 2007, 04:03 PM   #2
nobody has any experience of using an external drive with a laptop running final cut pro?
any comments appreciated
Old March 6th, 2007, 05:48 PM   #3
Ray,
I use external Lacie drives all the time with no problems (except for the fact that they're very fragile and have a habit of dieing on me).
Is your camera on the approved list of devices on the apple site?
You could try capturing short sections to your internal drive and then copying them across to the external drive, then reimporting them into your project. It's a bore but if you can't borrow a DV player or another camera it is at least an option.
Cheers,
Liam.
Old March 6th, 2007, 06:09 PM   #4
What is the format of your external drive?
Is it Mac OS extended (Journaled)? If not, try formatting it that way.
I use to have that kind of trouble, and after reformatting it, no more issues.
Rickey
Rickey Brillantes is offline   Reply With Quote
Old March 6th, 2007, 07:11 PM   #5
I was always under the impression that Journaling should be off for media drives and only enabled on system drives.
"We've done the impossible, and that makes us mighty."
Nate Schmidt is offline   Reply With Quote
Old March 6th, 2007, 08:04 PM   #6
IMO you should definitely turn journaling OFF on media drives. I've found that it doesn't have an effect on capturing video, but it creates a problem with dropped frames when printing to tape. FCP is very finicky about that for some reason.
Nevertheless, I don't think the drive's format would cause problems like you're seeing. There seem to be a lot of posts about firewire problems with FCP 5.1 and the Intel machines for some reason. Also realize that in spite of the different ports on your machine, all Macs only have one internal firewire bus and it supports both FW400 and FW800.
Also, there are known issues with Canon camcorders and Mac firewire. Not sure whether these are continue with the Intel machines and FCP 5.1, but in the past this was discussed frequently. The don't play nice with multiple firewire devices IIRC...
http://tech.operaphilly.com | The best in the business: DVinfo.net sponsors
Old March 21st, 2007, 10:01 AM   #7
journaling vs non journaling
So there is some disagreement as to journaling. Anyone else have an opinion?
Thanks in advance.
Boyd, you said all macs support firewire 800? I have an I-mac 20" with Core2Duo and osx 10.4.9.
How do I get Firewire 800? Buy an enclosure that supports it or is this a software configuration?
Larry Vaughn is offline   Reply With Quote
Old March 21st, 2007, 10:49 AM   #8
No, that's not what I meant although it might be interpreted that way, sorry for the confusion. What I said is that all macs have only one internal firewire bus and it supports all of the machine's firewire ports. So if your Mac has both firewire 800 and firewire 400, then they are actually both connected to the same bus internally. If your machine doesn't have an FW800 port, and if it can't take some kind of expansion card (like a PC card on the PowerBook or PCI card on the PowerMac) then I don't think there's any way to add firewire 800 capability.
IMO this isn't much of a big deal however. Both my dual G5 and PowerBook have firewire 800 ports but I've never used them during the 3 years I've had those machines. Firewire 400 has always worked fine for capture and editing on external drives.
Old March 21st, 2007, 05:06 PM   #9
Ray, is your "cheap canon" one of the ZR series? If it is it will not work with any external firewire devices plugged into your computer at the same time. I recently bought one with hopes of using it as a deck to keep the wear and tear off of my XL2, and was sorely disappointed. I called both Canon and Apple about the issue. Apple said to run some test on the computer to make sure everything was in working order, I did, it was. Canon said that all ZR series camera will not work with external FW devices plugged into the same computer. On my ZR800, the bad news was on page 46.
Don't know if this will help you out or not, but it may be an explanation.
"... the drama is on your doorstep..." - John Grierson
www.grvideo.net
Kevin Randolph is offline   Reply With Quote
Old March 21st, 2007, 05:38 PM   #10
If you have a PowerBook or a MacBook pro with a peripheral slot, then get a firewire card for it. I haven't checked out the new machines yet, but surely someone is making a firewire card by now? On my Powerbook I got a FW400 card for less than $30 at Best Buy. This gives you two independent firewire busses and should solve the problem with the Canon camera. It also speeds up big file copies between two firewire drives.
  You are here: The Digital Video Information Network > DV / HD Post Production... and Beyond! > Non-Linear Editing on the Mac
Google
