MPEG Streamclip closing unexpectedly at DVinfo.net
Final Cut Suite
Old July 9th, 2007, 02:24 PM   #1
When converting to AVI...MPEG Stream clip keeps stopping at about 4% complete and closing the program 'unexpectedly'.
Getting very frustrated.
It worked perfectly the first 2 times and now keeps doing this even after reinstall.
Thank you for any suggestions in advance.
Tobin
Clipping raw mt2 files, mac book pro 2.16 core duo, 2 gigs ram.
Tobin Strickland is offline   Reply With Quote
Old July 9th, 2007, 04:03 PM   #2
Are you using 1.8 or the 1.9 beta? Try them both and see if it fixes the problem.
Chris Harris is offline   Reply With Quote
Old July 10th, 2007, 01:19 AM   #3
Tried both and just tried to export it to the laptops hard drive instead of the external...still doing the same thing. Get's to about 3-4% of the conversion and quits the program. ...
Old July 10th, 2007, 01:29 AM   #4
Very frustrating, i had a similar problem.
It was suggested to me to e-mail the developer of the software, as he is apparently very receptive to how the software behaves.
worth a try anyway!
Neil Rostance is offline   Reply With Quote
Old July 10th, 2007, 05:34 AM   #5
Did you recently update your OS to 10.4.10? I did, and now FCP vaporizes while doing certain tasks. Arrgh. This is why they say never update unless you are absolutely certain ...
Dave Lammey is offline   Reply With Quote
Old July 10th, 2007, 08:10 AM   #6
10.4.9
I sent an email to squared5 the developer of mpeg-streamclip...waiting
Any other suggestions?
Old July 10th, 2007, 01:53 PM   #7
Still same after reinstall
Did a full system reinstall to clean out and make some needed Hard Drive space. Mpeg still closing unexpectedly.
Old July 11th, 2007, 05:08 PM   #8
Aha, it works fine if you input the frame rate. For 60i ...input is 60.
Old July 11th, 2007, 07:15 PM   #9
60i should actually be 29.97, and 60P should be 59.94.
Tim Dashwood
Tim Dashwood is offline   Reply
