Themis Gyparis |
January 13th, 2008 11:35 AM |
Mary,
I'm afraid I'm gonna have to ask this: is your Encore software genuine? Sometimes these errors are due to bad, pirate software.
If that is not the case you can try these:
1. Uninstall and re-install Encore and set up its preferences in the Edit tab.
2. The numbers you get is probably your final video's timecode. It seems at the certain point something's wrong with encoding. Don't use a bitrate higher than 8.000 and with this certain processor I'd suggest you also don't use variable bitrate but constant. Keep in mind that a video about 1 hour long can have a bitrate of 8000 but for a project 2 hours long, it can't be more than 6000, probably around 5500. As I mentioned to you on a previous post, try encoding on a different drive than the one that contains your system files and then burn to a DVD.
Also, it would be better if you used Premiere's Media Encoder to encode files and not do it from within Encore. It comes as a plug-in and you can buy it (I'm not sure about CS3 but you can check it out). Encore is mainly for DVD authoring and I wouldn't recommend that you use it to encode files.
My guess is you try to encode using VBR (variable bitrate). Try using CBR (constant bitrate). Your processor is rather "weak" to handle a two-pass encoding.
Finally, I'm also assuming that 5 GBs of RAM are way too much. That may also be the case with this piece of machine (by the way I'm assuming you're using XP PRO with all necessary service packs, right? And certainly not Vista, they are an enormous trouble-maker, at least for the moment). Try to stay with 2 GBs (max 4GBs) of RAM, I believe your system would work better.
