Upgrade a 2.40 Core 2 to a Quad??
I use PPro and sometimes another Adpbe app at the same time. Would upgrading to a low-mid range Quad make much of a difference performance wise?
(I have 3gigs of 667mhz RAM) |
I upgraded from my 2.4Ghz Duo to the 2.4Ghz Q6600 Quad core about two months ago and the move was definitely worth it. I'm running 6Gb of RAM, RAID-0 for footage, render time has improved a great deal.
One thing you might not be thinking about is power, my Q6600 was not running as well as it should have and after some research I realised my entire system was grossly under powered so I had to buy a 750W power supply. Useful link: http://extreme.outervision.com/psucalculatorlite.jsp |
See:
http://www.dvinfo.net/conf/showthread.php?t=119195 Since you have DDR2 667 memory I'd guess you'll have to buy: 1. New Motherboard 2. CPU, Q9450 or better 3. Possibly new memory(or go for the DQ6 DDR2 MB as I did) The gain in render speed is huge(mpeg2/HD) // Lazze |
I don't see any reason to toss the motherboard and memory necessarily. A lot of (most) boards that support a Core 2 Duo will support a Core 2 Quad. Q6600 and Q9300 are very viable, lower cost options too.
Robert, I don't agree
1. many modern MB's take the Q6600, but not the new 45nm penryn family 2. Q9300 isn't a good choice for video editining since it sports a cut down SSE4 set + half the cache size - and the lower price doesn't make up for it. As I said, he CAN reuse his memory if he goes for a DDR2 based MB. 667mhz memory modules are "slow" and he may run into FSB problems when using a modern/faster CPU(that is if he doesn't choose a MB with decoupled frequencis for memory speed and FSB). // Lazze |
- How are you sure that the improvement is not due to your RAID-0 and RAM? Thanks. |
I'm not sure how many boards will not support a Penryn (I haven't done anything like an extensive survey), but I sure have the impression that most being sold nowadays do. Some boards might need a BIOS update. If the OP's board will not support a Penryn, then a Q6600 or Q6700 are certainly viable options. At under $200 nowadays, the Q6600 offers a lot of bang for the buck.
Both the Q9300 and Q9450 support the same SSE4 instruction subset (4.1). The larger cache on a Q9450 doesn't do much at all for video encoding performance (it does help some games run considerably faster though). |
Robert,
You're right about SSE 4.1 (I can almost swear that when I checked the docs at Intel before the Q9450 was available here in sweden they had an "*" on the Q9300 on SSE4.1 - anyway its not there now. The Q6600 may be a more viable option in this case considering MB and "old" memory modules. // Lz |
