capture card recommendations wanted!
Hello.
well i just "upgraded" from a canopus raptor rt2 to a matrox rtx-100 it is NOT going well, i am not happy with the matrox rtx-100 there are simple features that it just doesn't support, like the safe zones and title safe zones in premiere, it isn't supported... the audio meters are wicked slow, like 10% as fast as they were in native premiere. the playback of the video on the computer monitor is crap, it looks like a mild blur effect was applied yet the playback on my sony ntsc monitor is fine. i still have the raptor rt2 card, i could go back to that but i was wondering what is everyone else using?? is the storm2 card any good?? matthew |
A lot of people aren't using such cards at all. And a lot are. The
basic questions you need answering for yourself is: what features do I really need and what would be nice to have. Also put your maximum price on the list. Then see if you really need such a card and which models you can afford. Then check out if any of those are good enough. There are a lot of threads on this subject already. I looked some of these up for you. Please take the time to read these. Thanks. http://www.dvinfo.net/conf/showthrea...threadid=20377 http://www.dvinfo.net/conf/showthrea...threadid=20569 http://www.dvinfo.net/conf/showthrea...threadid=20035 http://www.dvinfo.net/conf/showthrea...threadid=20084 http://www.dvinfo.net/conf/showthrea...threadid=18986 http://www.dvinfo.net/conf/showthrea...threadid=19320 http://www.dvinfo.net/conf/showthrea...threadid=19041 http://www.dvinfo.net/conf/showthrea...threadid=18466 http://www.dvinfo.net/conf/showthrea...=&threadid=763 |
Matt,
I've been using a RTX100 (with thier "Extreme") verison of the software for a while and have not seen the problems you're describing. In the past, I had a few questions and Matrox tech support was very good a resolving them. You can't always get through to someone the first time but they DO call back, usually within an hour. I would recommend calling them before you toss the card. |
yes i have been working with them. they had me reformat the system drive and reinstall xp pro from scratch thinking that the prior canopus installation was leaving gremlins behind.
it didn't help and by the time i was done reformating and reinstalling everything it was 4:37 and when i called everyone was on tech calls. i have the importing working fine with a very basic adaptec 1394 card and the default premiere capture utility. what camera are you using? i am very motivated to get the rtx-100 card working as i think the real time processing will greatly speed up my projects. matthew |
Matt,
Sorry for the delayed answer. I've used my GL2, a JVC Combo DV/VHS deck and a Sony DSR45 to feed the RTX 100 and have not had a problem at all. Wish I had some magic suggestions. Only recurring problem I have is the 'Digisnif" driver isn't loaded fast enough sometimes so I have to reboot when first opening PP. |
Matt,
How long ago did you purchase the RTX 100 - is it the extreme version, was it brought in Europe, middle east or Africa? The reason being that a batch of RTXs has a problem where there is no colour or horizontal colour bands on a PAL/TV monitor. Only cards belonging to lot numbers MD00010, MD00020, and MD00030 may be affected. This number can be found on your RTX PCI card on a white sticker. |
i have the ntsc and i just got it a week ago, it is the extreme version.
my problem is mainly that it captures my video in 720x480 with the pixels being at 1.2 instead of .9 if i capture the same footage in premiere with a standard 1394 card the video is 720x480 pixels .9 matthew |
Hi Mathew,
Sorry to hear about your Canopus experience. I dont know about Matrox systems, In Storm 2 you can select custom setting and change PAR (Pixel Aspect Ratio) . I think by default is already set to .9 I have Canopus Storm 2 and never had a single problem capturing videos 720X480 PAR .9, Editing IS another story, but capturing is The One. I'm changing lot of thing from my studio at this moment but one thing that will stay there is Storm 2.... at least for now. BTW Why did you switch to Matrox? |
Matthew,
I believe that when Premiere Pro loads up, you have an RTX 100 template - you need to make sure that you have set the pixel aspect ratio in there first before you start editing. |
yes in the matrox standard template the default is .9 for the pixel aspect ratio.
matthew |
