I can't capture audio
Hi,
Im using a S-Video cable to capture video from my camera, to my computer. Its been bother me that I cant capture audio, my card doesnt even have an audio in. My card is a: Pinnacle AV/DV card, im shooting on a HI8 camera (so so sad) and I have not a firewire output on my camera. |
Hi Curtis,
I have a feeling that you have to plug the audio out put of your camcorder into the Line in jack of your sound card. You might need to by a phono to mini-jack cable. I also think that this is mentioned in the manual. Hope this helps, |
Ok, so with the S-Video cable in my camera, I should also have the a/v cables connected and have the audio connected to the sound card? I dont know if my sound card supports that, its on the motherboard. I have 3 plugs on it, one for my speaker and two more.
Hi Curtis,
S-video only carries the video signal. So the audio would need to be connected to something else, if this is not supplied on the capture card, then you would need to plug the audio into the line in jack. The line in jack will be 1 of the two connectors you have on the mobo. Normally you have Speakers, Microphone and line in Jack. What you would then need to do is open up windows audio mixer, goto the record mixer and make sure that the line in is selected and that the volume slider is up. Pinnacle certainly would not have left audio out. As I said double check the Pinnacle manual. http://www.pinnaclesys.com/ProductPa...2&division_id= Is this the one you are talking about? |
Its amazing, it doesnt work.
Im now just using my a/v cables to capture video, yet no audio is to be heard. I've tried the audio plug in both input holes on my sound card, hoping one would work. I went into the capture settings in Pinnacle to select the audio source as, "Soundmax Line In" and that didnt work, so I tried the "Soundmax Aux" and that didnt work. In my volume settings, I have everything turned all the way up, for both my AUX, my Line In, and my Mic yet it doesnt want to work. Which is fantastic, it really is. Because everyone wants to watch a video with no audio what-so-ever. The last comments were sarcasm. Can someone get on msn or aim and please try to help me? I've had a bad day and I would like to sleep knowing this works. aim- blankcanvaslife msn- blankcanvaslife@hotmail.com |
<<<-- Originally posted by Ed Smith :
http://www.pinnaclesys.com/ProductPa...2&division_id= Is this the one you are talking about? -->>> No, thats version 9, I have 8. All I use Pinnacle for is video capture. |
Curtis: put your audio in the line in on your motherboard. Then
open your volume control properties and do the following: Options -> Properties -> Adjust volume for: Recording (!!) and make sure line in is selected in the list below this option. Hit OK and a different mixer comes up. Make SURE line in has a check in the little box below that is called SELECT. If so close the mixer and you should now be able to record from line in. The Pinnacle site clearly states in the specifications that analog audio is not available on the card (it is only through firewire) and that you must use your computers sound card for this. If you don't want to go through all of this analog hassle then there is another option besides getting a firewire enabled camera. And that is to get a analog to firewire converter like the Canopus ADVC100. With this you can just run all the firewire enabled problems and don't worry with anything analog. But, if you use this you won't need the Pinnacle card anymore (if you have a firewire connector available elsewhere). |
