4 channel audio help?
Dumb question. Need quick answer. Been editing with Premier and Matrox systems for several years. Trouble with Matrox system so I just switched to Premier Pro 1.5 software only mode. How do I capture the second stream of my audio? Matrox saves it as a separate .wav file, using only the Premier software I can’t figure out how to capture all 4 channels?
Steve |
As we discussed, Scenalyzer will probably do the trick. Here's a report on 4-channel even working in one pass!
http://www.dvinfo.net/conf/showthrea...+channel+audio |
Scenalyzer works great with 4-channel audio. And, yes, it will capture video + stereo 1 into an AVI file while simultaneously capturing stereo 2 into a separate WAV file.
