Put movie in this frame
1 Attachment(s)
Hi
Did someone can tell me how to resize video with premiere pro so that I can put it in the frame attached in this post. I was trying to combinate movement with 3d basic efects...but it's impossible to "fit" all corners. Someone can help me? Thank you! |
Re: Put movie in this frame
Corner Pin.
Go to the effects, highlight "corner pin", and resize the image in the monitor window. Don't bother trying to do it with the pixel sizes... Good luck... |
Hvala Majstore!!!
Check the result carefully when using CORNER PIN. Switch it on and off repeatedly and observe that it adds a slight blur to the image. A lot of people might not notice.
Wesley, is there any difference when you have "use maximum render quality" turned on and off?
