Letter fonts
Where do font letters come from? From Windows or from programs like Word?
There are some fonts which I had used, within Avid Xpress, in my previous setup which are not in my present one. Particularly one called "Papyrus" which was very nice, as well as some others. I thought it might be on different and older versions of Word, but I did install the ones I had and nothing. Where should I go to download letter fonts and where should I install them so they are available on all my applications? Carlos |
You can do a google search for free fonts, but be prepared for pop up hell. You can also purchase fonts, or buy programs that let you design your own. This is a last resort, unless you have designed a font before. I'm willing to bet you haven't? I do an online search for font sites, and then spend hours going through fonts, looking for the one I feel will convey the mood I want.
And you would likely unzip the file, and simply drop the file into C:\windows\fonts. If you are on a mac, you are on your own ;) |
I would also like to warn you- when you dump the files into your fonts folder, they will be available throughout the entire system. This is sometimes a problem. I had downloaded a bunch of Star Trek fonts one time, including klingon. One of my programs decided it liked klingon, and used it for all messages and windows inside the application. Now, I am a huge Trek geek, but I don't read klingon. That was quite an experience, to say the least.
Maybe there's a connection between Trekkers and font design... |
Well, it turned out to be easier than I thought.
Or at least was lucky to find a site that had lots of fonts: http://www.netfontes.com.br/ It's in Brazil, which is good because I need to have accentuation cappability. No pop-ups, probably because I used Firefox and it blocks them. No luck with that font I mentioned though: Papyrus. Is there any risk of the fonts having some virus or worm? |
I'm not sure about picking up viruses, but I assume it's possible, so use protection. As for papyrus, try using "fonts, papyrus" as keywords when you search. It may be a registered font, and you might have to purchase it with the rights to use it. And you might also find a knock off for free.
OK. I ended up solving it in a much simpler way.
I had a hunch these fonts might be in my wife's computer, which is in network with mine. And they were!... They probably came bundled with some program we installed, probably a graphic program of some kind, and it was deleted on my last install. So I simply transferred all the fonts she had and it's there to be used. In any case I will download some of those fonts available, as they might be useful. What I will do is put those fonts on the installing CD I always use, where I put all the stuff I need to have. Thanks! |
And you should get in the habit of copying the fonts used to a project file, in case you need to pass it off to someone else, or duplicate it later.
Good tip! We take so many things for granted, to think that a foolish thing like that can get you into trouble... Thanks again! |
